Question about RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors
Hydraulic fill AC 5050 - RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors
I took my bobcat post hole auger apart to service it and had to drain the hydraulic fluid! Now do I have to fill the auger head before connecting it to the machine? Or can the machine do it self?
if the hydraulic oil is from the auger head then the machine will fill and bleed out the air
the hydraulic oil would have been in the hydraulic motor that drives the auger
Jan 07, 2017 | Cars & Trucks
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic MerconĀ® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Where's the hydraulic oil fill for a John Deere 3020? Is it next the seat? What's the hydraulic system oil capacity? What type hydraulic oill would you suggest?
The oil fill cap is just above the oil dipstick at rear of tractor.
the capacity of the system is 4.5 gallons.
Oct 08, 2010 | John Deere Garden
It just wont turn on i have checked the power lead and its ok its an acer aspire 5050 laptop
Hi. I would suggest you double check the ac adapter if the powercord is properly attach to it ot also you might want to try powerdraining or powercycling your computer. To do this you must turn off your laptop then remove the battery and unplug the ac adapter then press and hold the power button for 20 seconds while the battery and ac adapter is out, after that place back the battery and plugin the ac adapter and try turning on your laptop, if this doesnt work then try power draining it again and just use the ac adapter or just plug it in without the battery then try again turning it on. If it still has the power issue then try a known good ac adapter so that you could double check that it is not an ac adapter issue or a battery issue. If all that trouble shooting step doesnt work then you could also try calling acer tech support to help you on your issue if your machine or laptop is still under warranty they would help you fix it by sending that laptop to there depot without any charge. Hope this Helps
Jun 09, 2010 | Acer Aspire 5050-3242 Notebook
Reboot system
my acer aspire is hang insert battery time,ac put normal work,my modle is acer aspire 5051anwxmi
Mar 29, 2010 | Acer Aspire 5050 5430 Laptop
When I turn it on I get no video at all. Not even
no lights at all? try removing the battery, plug the ac adapter see if it works, if not its may be the motherboard itself thats having some issues
Feb 14, 2010 | Acer Aspire 5050-3371 Notebook
Laptop battery problem
Try not to install the battery while its on. Power down the laptop then install the battery and power back on the laptop. Hope that helps.
Nov 10, 2009 | Acer Aspire 5050-3242 Notebook
My Acer 5050 will not charge the battery and will not run with the power cord.
power cord may be damage change i1st it to check.
the wire which connect in ac current.
Oct 30, 2009 | Acer Aspire 5050-3242 Notebook
How do you fill a ac delco hydraulic 3 ton floor jack model 34123 with hydraulic fluid
DONT KNOW WHO BUILT THIS JACK- AC DELCO JUST PUT STICKERS ON IT. TYPICALLY YOU REMOVE A PLASTIC SCREW IN PLUG OR A POP IN RUBBER STOPPER FROM THE TOPSIDE OF THE CYLINDER. WITH THE JACK ALL THE DOWN, FILL IT COMPLETELY UP AND IT SHOULD WORK. SOMETIMES THEY GET AIR IN THEM - JUST LEAVE THE PLUG OUT AND JACK IT UP A FEW TIMES, THEN INSERT PLUG. USUALLY 10 WEIGHT HYD OIL. OR "JACK OIL" AT THE STORE.
Mar 26, 2009 | Plumbing
Acer aspire 5050 can't turn it on
If you dont see any green lights and you dont hear any boot up sounds ( hd, fans, etc) try to take out battery and just plug in the AC adapter to a known good power outlet. Make sure your power plug is good too. If you hear boot-up sounds, see green lights but no display then toggle on the "fn" key and or try on an external monitor.
Dec 13, 2008 | Acer Aspire 5050-3242 Notebook
RTO Allis Chalmers Fuel Sending Unit 5040,5050... Tractors Logo
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
