Question about Poulan Garden
Mowers cuts cutting - Poulan Garden
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
sawdust46694
  • 398 Answers
SOURCE: mower is cutting grass uneven when mower is
all you can do is check the air in all 4 tires. pull it on level floor use a tape or 12 inch ruler to set the deck on the level. i have `12 mowers i keep going for a golf course. and this works great for us! And be sure to lift on each side of the deck while you check the right front left front, left rear and theright rear. look for sloppy adjustment holes and worn out rollers and deak wheels.
Posted on Aug 08, 2009
mickey813
  • 472 Answers
SOURCE: honda petrol mower starts but cuts out
SOUNDS LIKE YOU HAVE BAD GAS YOU MAY TRY CHANGING YOUR GAS
Posted on Sep 30, 2009
hunter19_46m
  • 7482 Answers
SOURCE: lawn mower keep cutting off when cutting the grass...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
Posted on May 24, 2010
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
The mower runs over the grass but leaves much of it uncut
You can look at two items.
One is your mower level. If you are up on one side it will cut uneven.
Check your blade it might be bend or dull and not cut good.
Jul 21, 2011 | Garden
LA110, 42" mower deck, 1
Check that the cutting tip of the blade that is cutting lower is not bent down. Also park the mower on a level surface and lower the deck and check the gap under the front of the deck is even. If not, there are levelling adjustments on the top of one side of the deck. Regards Phil
Apr 15, 2011 | John Deere 195HP Hydrostatic 42" Cut...
Poulan pro, right out ofr the box model pr625n21rh3 serial 012010m 004039. the problem is it won't cut the full width of the deck , have to overlap 3" to get full width cut????
This is a 21" mower, meaning the blade is 21" long (maybe only 20.5") and it will cut a 21" wide path of grass. Measure the width of the path that it cuts in the grass. If it is less than 21", then the mower has the wrong (too short) blade on it. It may just have a configuration of deck and wheels that make it look like it's not cutting as wide as it should.
Jul 28, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
12 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
