Question about Garden
Bmm 2400 mulchinator
How can I be sure that it is just the battery and not the motor that is wrong with the mower.
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: for my Ryobi bmm 2400, the light does not come on
Maybe the power converter unit in the charging system has failed.
Posted on Jun 11, 2010
  • 6468 Answers
SOURCE: Considering buying a 12 year old Ryobi lawn mower BMM 2400. Should it still be in working order? What about the battery?
most small batteries only last a couple years
Posted on May 01, 2012
I have a tandem pacer 2400 lawn mower, my gardener was cutting fairly wet grass, it tripped the power and now does not start, even left it for a few hours ? thank you Vanessa
have the lead to the mower tested and tagged
if there is any insulation problems in the lead , then the rcd breaker will trip from earth leakage problems
wet grass is very heavy to cut so the motor may have overheated
press the reset button if it has one or have the electrician doing the test and tag of the cord also check the motor
moisture and power do not mix so electric mowers are only suitable for dry cutting
Jan 14, 2017 | Garden
Went thru mower has new battery and silinoid universal type,fuse good,I turn key but will not turn over.Bumped starter from car and motor turned over,starter and motor work so what is wrong?
Not sure of total problem but I would start by cleaning the inside of battery cables. If I understand you can jump the battery and the unit will start so the battery cables may be dirty and not getting enough power from the small battery in mower.
May 05, 2016 | Garden
Toro wheel horse 13-38xl lawn mower won,t start, makes buzzing sound when key is turned on,checked solenoid with screw driver but will not start motor, tuned pulley under motor and wheel on top of motor...
If you crossed the two battery terminals on the solenoid and the engine did not turn over, I would check the battery terminals first to see if they are tight. Then check the terminals at the solenoid to see if they are tight. If all of this is tight and you are sure you have 12 volts at the solenoid, then your starter is bad.
Aug 23, 2013 | Garden
I have a craftsman with a kohler magnum 18hp. If i put a battery charger on my battery it dont charge i can turn the key and it wont roll over. If i jump my lawn mower and it running i can turn the key all...
Hi, if your battery wont charge you will need to replace it and when you do you need to check that the mower is charging by checking the battery voltage with a multimeter while the mower is running. It should be around 14 volts. Regards Phil.
Sep 06, 2012 | Craftsman Garden
How do I get a new solid state ignition. My crruent leaf blower is not getting any spark
Hi, most lawn mower repair shops either will have those in stock or can order them for you. Its a common item, or you can go to www.mtd.com and order it online. Before repalcing the coil, remove the kill switch wire from the coil, then check for spark again. you could have a defective kill switch.
Sep 24, 2010 | Yard Man Mulchinator QuickShift BlowerVac...
Will not start< electrical problems.
voltage isn't the problem here. You are correct in using the 12volt battery. However, what you need is more power and power comes from the amperage. Make sure the battery you have, has sufficient CCA (cold cranking amps) for your new starter. Try removing the battery cables and jumping from your car. Make sure you ground the black lead on your car (not hooking the black cable up to the battery directly) if that doesn't start your mower, you have a different problem all together possible being the new stater and hopefully not compression problems steming from the intake and exhaust valves. There are typically saftey switches to shut down or prevent the motor from running. Easy trouble shoot, if the starter kicks over, it's not a saftey switch.
May 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MY car is having the same problem. I
no take it out go to a part store and buy a 12 volt cars use 12 volt batteries not 9 unless it is a lawn mower or a motor cycle in the shape of a car just joking about making fun but really hey take 12 volt batteries
Aug 28, 2009 | 1997 Saturn SL
Mowing blade turning the wrong direction
I think you did diagnose the problem. A DC motor will run backwards if the wires are switched around and polarity is reversed. Try switching the wires
Jul 02, 2009 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
