Question about Vacuums
Neato robotic vacuum won't charge - Vacuums
Neato robot turns on, fires up vacuum/brushes, but won't move - no error messages. What gives?
I have a Neahis to Botvac 85, had also problem, it started up then stopped. It is 2 or 3 years old, don't remember. but it started to ack very strange with the battery. then this start/stop problem came. I ordered a new originial battery and thought it should solve the problem but no it didn't After some time I decided to try again. Started Neato and it stopped after some time, then I wanted to see if the lidar was rotating so I removed the blue cover over the lidar and could see that it was rotating, then I touched it little bit and the neato started and started to clean my floor. so try this.
Sep 12, 2014 | Neato XV-21 Pet & Allergy Automatic Vacuum...
Neato won't charge
Hi, it's Jeremy from Crucial Vacuum.
Try charging your Neato vacuum directly with the plug. If you take apart the dock you will find the plug inside. Plug that plug directly into Neato and charge the Neato until its light is green. If your Neato's Battery charges and it works ok, reassemble the base with the charger making sure that the plug you plugged into your Neato is plugged FIRMLY into its connector inside the base.
You can purchase direct your replacement Neato parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=neato&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Neato Vacuums
Neato vacuum display will not come on.
Here is a video showing a quick temporary fix and the full fix showing the change of all the electrolytic capacitors.
Jul 04, 2014 | Neato XV11 Vacuum
Green light but won't start
Jun 14, 2014 | Neato 945-0041 XV-21 Robotic Vacuum...
Why does my neato xv-12 keeps saying "put me on the floor" but it is and I cannot turn off
There are sensors in the wheel housing that let Neato know whether it is being held (wheels protruding from the frame), or whether it is on the floor (wheels tucked into the frame). If those sensors are not working, you will need to have the unit serviced (if under warranty), or you can look up information on how to correct the problem yourself (if out of warranty). This information can generally be found by searching the Neato Robotics forum at:
RobotReviews com
May 11, 2014 | Neato Vacuums
Will not charge
This could point to several causes:
1) Accidentally disconnected battery or batteries inside Neato
2) A charger that is not properly assembled (check charging block connections)
3) A dead battery
4) A defective charger
5) Defective charging circuitry on the Neato motherboard
The easiest way to determine the actual cause is to thoroughly research each potential cause on the Neato Robotics forum, found here:
Mar 04, 2014 | Neato XV11 Vacuum
Where can i buy replacement side brushes on line for x500 robot vacuum
Try a site called www.ereplacementparts.com. They carry parts for stuff I never heard of.
Nov 12, 2013 | Neato Robotics Neato XV-21 Pet & Allergy...
Neato vacumm won't turn on
Apr 17, 2013 | Neato Vacuums
Using neato in a new home. It doesn't seem to be mapping properly and won't di the whole room.
Make sure you have updated the on-board software to the latest version, 2.6.
http://neatoroboticsupdates.com/
Joe www.joeramsay.ca
May 29, 2011 | Neato XV11 Vacuum
Vacuums Logo
75 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
