Question about Boating
How to remove propeller from 2007 40 hp mercury out board
    Sergeant:
  • 352 Answers
REMOVE LOCKING TAB, UNBOLT NYLON LOCK NUT...DISCARD!
PROP SHOULD SLIDE OFF OUTPUT SHAFT...IF NOT PROP IS FROZEN.
IF IT A THRU HUB PROP, AND HAS A RUBBER SHOCK ABSORBING DEVICE...YOU CAN'T REALLY HEAT IT..YOU DEFINITELY DO NOT WANT TO BANG ON THE PROP(SHAFT AND BEARING DAMAGE)
SOMETIMES THE PROP HAS TO BE CUT OFF...REQUIRING A NEW PROP!
TIP: IF THIS IS THE CASE:*** ALWAYS COAT PROP SHAFT WITH ANTI-SEIZE COMPOUND WHEN INSTALL A PROP!!!!!
Posted on Jul 21, 2013
2 Suggested Answers
SOURCE: remove bent propeller shaft 25 hp mercury two cycle boat motor 2005
Take The Propeller Off,
Use The Rear Thrust Washer As a Tool Turn It Upside Down And Put It Back On The Prop Shaft The Three Slots Should Match With Bearing Carrier.,Undo Three Bolts On The Carrier In The Back Of Gear Box,
Turn Carrier Counter Clock Wise Until It Is Loose Remove Prop Shaft Complete With Carrier and Reverse Gear
Posted on Mar 17, 2013
Other than head gasket how can water get into oil on 90 hp 4stroke merc ob
Water seldom gets into the engine oil, but more often in the lower gear case through the seals behind the propeller. If you have water in the oil of the head unit, then a blown head gasket is likely the cause.
Seems to be a known problem, and may just be the gasket between upper and lower unit.
https://www.google.com/search?q=water+in+oil+mercury++90+hp+4+stroke
Aug 29, 2017 | Cars & Trucks
What year mercury out board 7146536
You left out the crucial number, H.P.!
All the info is here
mercury out board Google Search
Jan 23, 2017 | Mercury Computers & Internet
I have an 80s model 40 hp Yamaha out board. it leaking gear oil from behind the prop.
two seals on the prop shaft.fishing line is deadly on these seals.take it to a shop that has the tools to do the job.
Jul 28, 2014 | yamaha boats Yamaha 6B500 Jet Boat Engine...
Remove bent propeller shaft 25 hp mercury two cycle boat motor 2005
Mar 16, 2013 | Boating
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a 1990 4hp mercury out board will a 5 hp prop fit
As long as it will actually go on the shaft, there will be no problems with changing to the other prop.
Oct 05, 2009 | Sport & Outdoor - Others
Motor ticking
make sure the propeller is not lose and check the bearings
Feb 01, 2009 | 2001 Chevrolet Impala
Boating Logo
105 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
