Question about Sony SPP N1025 Cordless Phone (spp-n1025)
Handset my handset. when i push "talk" display "no conection" battery is full charged base and handset are closer. help!!!!
Presume you are talking about the extra handset. Try placing the extra handset in the "main" base for 5 seconds.
Posted on Aug 28, 2007
I have a Panasonic KX-TG5633. It has worked fine for several years. suddenly one of the handsets no longer syncs to the base. I've followed the instructions to register it to the base, but it refuses to...
I am so tired of all the answers that don't help by repeating standard answers that you already know won't work or giving directions for a totally different product. The fix here is simple but not easy. It's either a bad charging/battery connection, a bad battery or both. Low power will cause the exact problem asked here.
As the phones get older, and I'm specifically talking about Panasonic cordless KX-TG563x but this may be true of other rechargeable devices, the metal contacts for charging and battery do not make a good connection like they used to. They may look perfectly fine and free of corrosion but are not actually making a good connection.
Symptoms include the phone getting hot while charging and not holding a good charge. The phone may show 3 bars of charge but still blank out like the battery is dying. With these Panasonic phones, weak battery will cause the phone to unregister and will give false charge level readings in the display. If your phone gets hot when charging, this is most likely your problem.
I had this problem with several handsets and used contact cleaner on the charge base, the phone contacts, the battery contacts inside the phone and on the battery itself. It fixed all the registration, heating and charging problems. I had one stubborn handset I had to clean multiple times but it's now working like new as well. I used DeoxIt contact cleaner from Caig, bought it on eBay. Great stuff. If repeated cleaning of the contacts with a good contact cleaner does not fix the phone, replace your battery. Use contact cleaner on your new battery for best connection. Ebay is a good source for replacement batteries as
well. Good luck!
Feb 11, 2011 | Panasonic KX-TG5633B Trio Cordless Phone
The telephone batteries are fully charged; however when I attempt to use the telephone I receive a message stating, "No link to base. Move closer to base, try again." The telephone is very close...
Check your user's manual for registration, or RE-REGISTER the handset to the base. In essence, it involves stepping to the registration on the handset, pushing the handset locator button on the base, then saying OK on the handset. They will sync up.
Feb 10, 2011 | Panasonic Lands Phones
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Feb 14, 2010 | Uniden Cordless Phone
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
No link to base.
unplug the base and when you plug it back in
the handset should work
Dec 13, 2008 | Panasonic KX-TG2356 Cordless Phone
Searching is displayed on handset and Y icon is blinking, looks like a twig sign, have tried move closer to base station, base station is on reset unit restart handset reg, have tried all but gets to...
Turn base around and find the area which says pager/registration. Push this button after you set internally the handset registration.
Menu/H set settings/Reg. Handset
Dec 03, 2008 | Lands Phones
Model 25922 5.8 GHZ Cordless phone with one main phone and two extras
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Ge Telephone Solutions
Handset can not link.
• If any handsets become inoperable, place it on the main base cradle for 20 seconds to re-register.
No dial tone
• Check or repeat installation steps
• Make sure the base power cord is connected to a working electrical outlet.
• Make sure the telephone line cord is connected to the base unit and the modular phone jack?
• Disconnect the base from the wall phone jack and connect another phone to the same jack. If there is no dial tone on the second phone, the problem might be your wiring or local service.
• The handset might be out of range of the base. Move closer to the base.
• Make sure the battery is properly charged (for 16 hours).
• Ensure the battery pack is installed correctly.
• Did the handset beep when you pressed the TALK/CALL BACK button? Did the in use indicator come on? The battery may need to be charged.
Sep 02, 2008 | GE 26998GE1 Cordless Phone
Handset Buttons Stopped Working - Full Battery
Here is a link to Uniden's site, and on the right side of the page, there is a link for a download manual pdf and helpline
also worth checking if any buttons are stuck, or if the handset is set to pulse rather than tone mode, or if it has had a tumble or knock, possibly the keypad connector has come loose .
Hope this helps.
Sep 17, 2006 | Uniden TRU8885-2 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Sony SPP N1025 Cordless Phone (spp-n1025) Logo
230 people viewed this question
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
