I have a es8-25h sullair that will run at full discharge pressure for a day or two but than it drops off to the point where the other unit kicks on to make up its loss, I've checked over the air filter, checked the inlet valve actuation and all connections what do you suggest would cause this?
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
SOURCE: Pressure won't build up in tank
Your compressor is the oilless type that incorporates a vinyl/teflon piston ring and a cylinder that is open from the bottom. Remove the cover and push the piston to upmost position. Look for scratches along the upper portion of cylinder. If scratched, compression is leaking thru ring and will not fill tank. Replace with Sears part #k0650 cylinder /piston ring kit to restore full power. While the compressor is apart examing the valve plate and reed valves for wear. If worn replace with part #z-ac-0032. Reed valves tend to crack or loose their shape reducing efficiency. If cylinder and ring are in fair condition, then most likely reed/valve plate is the problem. Good luck and email if you have more questions.
SOURCE: Dewalt 4 gal air compressor will not build pressure in take.
The bleed valve is an unloader of sorts that allows the compressor to start with-out a load. It closes when the pressure in the airline reaches about 20-25lbs with good volume. If air volume is not sufficient, the valve will not close. To solve the problem lets do a few tests. A long cord will reduce power and reduce air volume. Try powering the compressor with-out extension cord. If bleed valve closes when you do not use a cord, the compressor is not getting enough voltage, use shorter cord of the 12 gauge quality and more hose to reach work. If valve still does not close, check for air leaks on all fittings including around pressure switch and drain valve with soapy water. Repair as necessary and retest. If no leaks were found, temporarily plug bleed valve port with screw/bolt and run compressor till set pressure cut-off while counting minuites/seconds. The compressor should fill and shut off within three minutes or so. If it takes an unusually long time to fill, then the reed valves /valve plate is worn and leaking pressure back into cylinger. Leaking valves will usually result in very hot discharge airline/air. Reinstall the bleed valve after test. Parts and partslist are available at www.toolpartsdirect.com . Good luck on the repair and email if you have other questions.
SOURCE: WILL NOT BUILD UP AIR PRESSURE PAST 20 LBS.
Check to see if air is leaking past 'pressure relief' valve. It's probably leaking and that's where all the air is going.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
