Question about Whirlpool LAB2700ML Pedestal Drawer for Duet Washers & Dryers
Washer dryer stopped turning
My washing machine hoover ultra care 1600 washer dryer while washing suddenly stopped turning . i pumped the water out and tried the dryer ?? the drum still did not turn. there was no smell of burnt motor. the fa belt is ok so either the pcb board or capacitor or the main switch has gone . which one do you think most likely many thanks
  • 29 Answers
If the capacitor goes, the motor does not get the kick it needs to start. if it is intermittent then that would be the capacitor as the belt would just mean not drum movement (if belt drive )at all.
Posted on Apr 13, 2008
Dovi thanks a lot for that advice will give it a try.
Posted on Aug 28, 2007
  • 641 Answers
Replace capacitor first. Good luck!
SOURCE:
Following freeze, water is gushing underneath hoover washing machine when mains turned on.
You'll need to tilt it or remove the back or pop the top to see where the leak is coming from. Unplug it first. I had my water pump crack and leaked. It was a plastic part not related to freezing though, and it only leaked when it ran a cycle. Perhaps your leak is prior to the water pump.
Mar 10, 2018 | Hoover Washing Machines
Hello, I have a Siemens 1600 WXL166AGB (1600 XL) washing machine. there is a humming while still washing and then it stops and beeps on drain, but not every time. have cleaned out filter, impeller turns,...
Sometimes the impeller can wear so that it is pulled to one side and jams intermittently. Try removing the pump and running it outside of the machine to see if you can catch it misbehaving. Or just replace the pump.
Sep 13, 2013 | Siemens WK61420GB Front Load Washer /...
Our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Jan 21, 2009 | Hoover UltraCare HC6 130M Front Load...
HOOVER 500M0AUS WASHING MACHINE
I have a Second Hoover HTC243 , I don't have the user manual . I don't know how to use it , can u tell me how to use it
Aug 15, 2008 | Hoover HTC243 Top Load Washer
Delay Star
pump blocked try lowing drain hose to see if water will drain freely and then remove kick plate at bottom and carefully undo filter to pump to look for blockage . There will still be water in this part, per pair to get a wet floor ..Also un plug /switch off washing machine before doing any repairs
Jul 19, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Vision 1600 drum not spinning?
Have the same problem, different model and it looks like I am outside 5 years spare parts. Probably just a belt or something from overloading. Also looks like it would nearly be cheaper to buy a new machine.You must have checked your pump???? What a rip off
Nov 27, 2006 | Hoover HF7 160E Front Load Washer
Washing Machines Logo
163 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
