How to install a ribbon in an underwood 310 typewriter
  • 3594 Answers
SOURCE: Can someone tell me how to install a ribbon in an
Almost all manual typewriters are roughly the same. The ribbon winds to the outside of the spools, put it on the spindles that way, from the spool to the outside of the guide roll, tru the slot in the reversing arm tru the ribbon lift and back the same way to the other spool.
Posted on Apr 07, 2009
  • 3594 Answers
SOURCE: Does anyone know how to thread a ribbon in an old
I'll try as they are all pretty much the same. First type with the ribbon off to determine witch way the ribbon winds either to the outside (most common) or to the inside. Drop the ribbon on, if there is a reversing eyelet in the ribbon be sure it is wrapped onto the spool. The ribbon comes off the spool then there may be a guide or roll for it to pass around, then it will go thruogh the reversing arm then through the ribbon lifter aback the opposite way to the other spool DickyO
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: I'm trying to thread a ribbon through my old
First, type a few letters to find out which direction the spools wind the ribbon (either to the inside or outside). Make sure the spools are installed to wind the ribbon in the correct direction. Second, make sure there is some ribbon wound in the empty spool so the eyelette on the ribbon for automatic reverse does not cause a jam by getting on the carriage side of the reverse guide. Take one spool in each hand, and let just enough slack in the ribbon to insert it behind the ribbon guide next to the platen. Note: the ribbon must go behind the two middle fingers of the guide and in front of the two outward fingers of the guide. If the guide has downward hooks on the outward guides, make sure the ribbon goes under the hooks to prevent the ribbon from bouncing out of the guide during typing. Next, make sure the ribbon passes through the metal guide fingers in front of the ribbon spool holders (these are for the automatic reverse - make sure the metal eyelettes in the ribbon stay on the spool side of the fingers or you will not get a reverse, and the ribbon will jam). Place the spools on the spindles of the spool holders. If the spool is hard to mount, check to see if there is a slot in the ribbon spool to align with a lever or mechanism on the spool holder of spindle. Hope this helps.
Posted on Jun 26, 2009
  • 16 Answers
SOURCE: How do I replace the ribbon on an Underwood
Really? An Underwood typewriter?
First, do you have a replacement ribbon that is not dried out? Does the ribbon come on one spool or two?
If the typewriter already has a ribbon installed, it is a simple matter of noting the path the current ribbon follows, and which way the ribbon winds onto the spools. Then install the new ribbon following exactly the same threading path. If there is not already a ribbon installed, then it is a little more complicated, and it will depend on your spatial relationship visualization skills.
1. Type a few letters on the typewriter, and take note of which way the spools turn.
2. Mount the two new spools containing the new ribbon so that the full spool will supply (unwind), and the empty spool will take-up (wind) the ribbon.
3. Thread the ribbon through all of the guides in the threading path - there are probably about 6-8 guides that the ribbon has to go through. The most important guides are the ones that carry the ribbon in front of the typeface elements as they strike the paper. But equally important are the guides that monitor the tension of the ribbon - they will cause the spool advance mechanism to reverse the ribbon take-up direction when the ribbon reaches the end of travel.
Posted on Sep 22, 2009
  • 3594 Answers
SOURCE: how to install typewriter ribbon on a Sears typewriter model no 2
I believe this T/W takes a Gen. Ribbon T5 or T7. Check to see which way the spool turns over 90% wrap to the outdide of the spool. Put it on to wrap in that direction, the ribbon will have an eyelet about 6" from the end be sure that is wrapped on the spool. From either side put the ribbon tru the reversing arm, tru the lifter, tru the other reversing arm and back to the other spool.
DickyO
Posted on Jan 19, 2010
Ribbon will not advance
Sir/Madam, I'm very sorry; this"fixya.com" assumes I have the knowledge to offer advice on typewriters but I normally need advice myself. Regret I can't help, Sincerely, Edwin Thoma, USN-Ret.
Sep 05, 2014 | Underwood 1957 Leader Turquoise Portable...
Olivetti Underwood Studio 44 ribbon won't advance.
Remove the top cover, remove ribbon spools, press a key and grab it with your finger, note the mechanical motions toward the ribbon advancer movement, usually found near the center of the ribbon holder or could be on the outside edge also, there is a reverser mechanism also that should be fully to one side or the other, it switches the ribbon direction to avoid a 'dead end' while typing. By moving the key toward the platen and away it should drive the ribbon mount spool by a shifting drive lever of some kind. If you cannot resolve this issue, take it to a rare typewriter repair shop, it is too hard to explain in this format, and mechanical skills are involved, hope you have them, ;)
Sep 14, 2013 | Underwood Retro green Olivetti Studio 44...
Comppatronic 310 what tye of ribbon
I
can't find any brother typewriter model Comppatronic 310
DickyO
Dec 24, 2012 | Brother Office Equipment & Supplies
I have an OLD Underwood (non electric) tyrpwriter and don't how to install the two reel ribbon...please help...
First determine which way the ribbon turns most wind to the outside but a few wind to the inside. Put the ribbon on the posts so it winds properly then put it thru the reversing arms. then thread it thru the lifter you'll have to figure that by yourself as there many different set ups.
DickyO
Mar 19, 2011 | Office Equipment & Supplies
I recently acquired a vintage underwood 315 typewriter. I bought new ribbon, 2 spools black. However when I put the spools on I cannot get the screws to do up as nothing comes far enough up the spools to...
Dear Pat,
I also own Underwook 315 typewriter and can understand your problem well. Probably you are not using the right spool. The height of the spool is causing problem for you. Please check the height of the spool which should be exactly 1.5 cm. If the one you are having is more than 1.5 cm height then get it changed. Hope it should work thereafter.
Feb 13, 2011 | Olivetti Office Equipment & Supplies
How do I replace the ribbon on an Underwood typewriter?
Sep 22, 2009 | Office Equipment & Supplies
Can someone tell me how to install a ribbon in an old underwood typewriter?
Apr 06, 2009 | Office Equipment & Supplies
Does anyone know how to thread a ribbon in an old underwood typewriter?
91 people viewed this question
k24674
jasbo
jasbo
