PRMDB-1956-6 While I am changing budgeted unit of a resource for an activity mentioned error code will be appeared and software terminates operating except I exit. what is should I do ?
  • Saeed Amjadian Jul 16, 2013
    This error ocurred in Primavera P6 software.
  • 3 Answers
CorelDRAW Graphics Suite X6
Instalation Code: XXKU-7WNM-TT98-WS6V-MMBT
Serial Number: DR16R22-H4C452J-UJYVTXG-WA3HXCJ
Activation Code:
Posted on Jul 15, 2013
3 Suggested Answers
  • 23 Answers
SOURCE: Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Posted on Jun 18, 2009
SOURCE: Exiting tally
Exiting tally
internal error. contact tally solutions
Software exception c0000005
(memory access violation
Posted on Jan 01, 2010
Plz give me serial number of Adobe photoshop cs 2
SN: 1045-1850-8064-4100-9918-1956
then you should give me request code
then i will give you activation code
Jan 05, 2017 | Adobe Computers & Internet
Primavera error codes
Wrong category, but see if the below link has what you're looking-for.
Primavera SDK Programmer Guide
Apr 23, 2014 | Computers & Internet
Errror 85
How to fix the System error 85 has occurred?One thing to mention is that even though you may be mapping some drive letter to a network resource, the same drive letter for other Terminal Services sessions may work as expected.
Use another drive letter...
Another point is that a different drive letter that is not typically used also works as expected. If it is feasible for you, use different drive letter when mapping to your network resource.
Restart Terminal Services-based component...
If using another drive letter to map your network resource is not an option, you can try to correct the issue by restarting the Terminal Services-based component.
Restart Terminal Services...
Another way to fix the problem is to restart the whole Terminal Services service. You can do so by executing the following steps:
-> Go to the Start Menu
-> Run
-> Type services.msc and hit ENTER
-> Locate Terminal Services
-> Right click it and select RESTART
This should break the connection between the Terminal Services and the resource and make the network drive letter available for your use.
Upgrade Windows...
The good news is that some attempts have been made by Microsoft to handle this error message and the underlying causes by Windows. The System error 85 has occurred was often visible in Microsoft Windows 2000. The Service Pack 3 and Service Pack 4 include some fix for this.
Sep 06, 2012 | Foxconn Computers & Internet
I have an 18000BTU unit that has an LED that flashes 5 times and then stops,could you pls advize as to the error code of the LED flashes.
You haven't mentioned the brand name. As the error code changes brand to brand I give some solutions. Check with your unit.
e-5 Outdoor activation of compressor over heat protection-Clean condenser coil and check out door f.motor speed. If less replace capacitor.
e-5. Blower motor lock Rotate manually. If hard to rotate, replace bearings or motor. If easy to rotate, replace capacitor.
Please mention brand name and other full details to get solution quickly. Thanks.
Jan 10, 2011 | Carrier 36KCARMS Air Conditioner
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Ereader library won't open
Hi.
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the Windows Operating System or if certain folders used by the Reader Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/uninstall-ReaderLibrary.sh". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
Feb 25, 2010 | Sony Reader Touch PRS-600
Canon IP3000 fault
Here are a couple of documents related to your problem (appears to be a print head error);
Error code synopsis;
www.decopac.com/resources/PDFs/iP3000%20Error%20Codes.pdf
Full product manual;
www.soft-manufaktura.ru/manual/hp/iP3000sm.pdf
Doesnt look terminal, at worst may need to replace the Print Head.
Hope this helps.
Dec 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My product activation key code has expired and i want a new code, please... where could i get for a free download of new windows vista OS? I want to have a temporary or a permanent product activation key...
I'm sorry, but it's not the policy of Fixya.com to supply activation codes for software. You will need to contact microsoft, and activate your code, this can usualy be done free over the telephone, or via the internet.
Nov 03, 2009 | Microsoft Windows Vista Ultimate Edition
Authorization Code
SN: 1045-1090-6246-8353-3166-2968
AN: 3688-1506-3421-2294-1142-3142-4063
AT: Normal: 194:13
help me please with A.key !!!!
Sep 24, 2009 | Adobe Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
