Question about Drills
Ironsmith drillpress switch - Drills
Asquith drill
It may mean feed and coolant.
Nov 27, 2013 | Drills
I have a Delta DP200 drillpress. The motor is scorched. Can anyone advise a heavier duty motor (e.g., 1/3 or 1/2 hp) that will work with the same 4-hole mounting plate? is it common practice to use older...
Motor amperage and HP go hand in hand. Get the biggest motor that will fit and you will be fine. Better too big than too small - the latter will have higher tendency to burn out with heavy jobs like yours did.
Aug 31, 2017 | Drills
Key chuck fits bad
replace key chuck, go to local hardware and see if they carry them, or contact company who made drill press, chek online internet.
Oct 10, 2012 | Jet 354165/JDP - 15M 15 Bench Mount Dril...
Where can i find parts for a clarke drillpress
Try Machine Mart who sell a large range of Clarke tools and machines.
Aug 01, 2010 | Drills
I need a work plate for a drillpress #1000
If you have the 5 speed model the table number is BT1000-0005 and you can go to Clarkeusa.com to order this part. That is where I found the breakdown for the tool. Let me know if you need more assistance.
Mar 14, 2010 | Clarke Power Products Clarke 16-Speed...
Need a bearing for clarke metalworker BT 1029-1 drillpress I
could be either BRG60203 or Brg60202, I suggest going to clarkeusa.com and looking at the breakdown. You can buy a bearing at any repair shop if you can get the ID number off the bearing, it doesn't have to come from Clarke. Let me know if you need more assistance
Feb 28, 2010 | Clarke Power Products Clarke 16-Speed...
Chuck came off Dayton 4yg14 Drillpress
Sounds like a Morse taper chuck. Might use a spot of glue to keep together.
Oct 27, 2009 | Drills
How do I change the font size on new acer aspire one netbook, its to small, help, ironsmith@excite.com
If you are asking about the web page font, you can increase the font size most of the time on most apps by hlding down the Ctrl key and tapping the + key.
Sep 28, 2009 | Acer Computers & Internet
Chuck seems to be bent
Make sure bit doesn't have any burrs caused by slipping in a chuck.
Jan 05, 2009 | Jet 354165/JDP - 15M 15 Bench Mount Dril...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
