How to format a olevia 226-t12 for hdmi
I am Trying To Hook My X-box 360 To My olevia 226-t12 Using A hdmi Cable so that I can play 2 player Mine Craft when I select the input on the tv it reads invalid format. what do I need To Do?
SOURCE: sony bravia won''t play PS3
Try setting the resolution to a higher grade or a lower grade.. That solved the problem for me.. good luck!
Posted on Jan 06, 2009
SOURCE: Received used Olevia 226-s11 hdtv, hook-up up (no
I need to go to Menu, Picture, Mode, Home.....
The default setting for the TV was Showroom which wouldn't let the cable signal through. Thanks for trying to help.
Posted on Jan 13, 2010
  • 6 Answers
SOURCE: I have an LG 42LC2D TV with INVALID FORMAT ON HDMI2
I have had this same issue.
Problem your tv isnt true 1080p meaning it will not work however when you switch to componet cables goto menu then change the display settings to 720p or 1080i then your HDMI connection should work fine.
Posted on Jun 16, 2010
budmrtn
  • 11361 Answers
SOURCE: Receive an invalid format message from my Olevia 32 tv
You get invalid format, or format not support becuase the video resolution setting on your PC is too high for the monitor to display, you need to lower your PC video resolution to the native resolution of the TV to get the best picture. Look at the owner manual for your TV or search the web.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 11, 2010
SOURCE: I have a LG 42PC5D Invalid Format on Screen HDMI VGA and PC
I have a LG plasma and I am trying to connect my PC via VGA and I am getting the "Invalid Format" - can you please tell me what is the problem? Thank you
Posted on Sep 22, 2011
Hi I just bought a pioneer vsx-42 cable box and was wondering how to hook my Xbox 360 up through there so I can play on the tv, I have an hdmi cord And will be playing on a Samsung smart tv
Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
Aug 02, 2012 | Audio Players & Recorders
Invalid format on hdmi
Unplug set, HDMI, and a box if used for a while--connect the HDMI first and then power to set and or box--see if set will reboot or box.
HDMI does not like power loss, being connected or disconnected with power on etc.
Also in set menu make sure HDMI input is "available".
Apr 29, 2012 | Olevia Televison & Video
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
Need code for my Cox Remote Control for my 26-inch Olevia 226 T12
We had this same problem as well and we finally found the answer, the code for the COX remote (silver on top black on bottom) is 1240.
Feb 21, 2010 | Olevia LT27HVX 27 in. LCD Television
Jan 12, 2010 | Televison & Video
How to hook updvd player to tv set
if the dvd player has hdmi connection use that.
if the TV has hdmi input use that.
if you can do both of these then use the TV remote to switch input to hdmi when the dvd player is on.
as an extra you can use toslink optical or coaxial digital cable from TV to home theater receiver for surround sound.
Jan 02, 2010 | Olevia LT37HVS 37 in. LCD HDTV
How to hook up a game console to an Olevia 232-T12
It all depends on your game console.
You can connect most to the Component, Composite, or HDMI inputs.
For modern consoles, use HDMI cables or provided Composite cables.
HDMI = Single cable and single plug (Best)
Component = Red, Green, Blue, Red, and White plugs (Average)
Composite = Yellow, Red, and White plugs (Worst, used for most older consoles and older TVs)
Nov 25, 2009 | Televison & Video
Problem with Olevia 226-T12 firmware install
the only thing is to keep trying it but you might want to leave the television off over night and then try it the next day.. also try doing the firmware on a 1G or less thumb drive...if the television is still not grabbing the firmware then it sounds like the television will need to get service... this means the television's main-board will need to be flashed.
Since the Manuf. of Olevia is out of buss the only company at this time that has the tool and parts to repair the television will be the 3rd party repair center called Amergence Technology ( 866-965-3842)
Jul 29, 2009 | Syntax Olevia 226T 26 in. LCD Television
Video Inputs for Denon AVR 589
manual is here: http://www.usa.denon.com/AVR-589-OM-E_006.pdf
Note on page 11 says "because video signals are out put from the AVR-589's monitor output terminal IN THE SAME FORMAT AS THE VIDEO SIGNALS, THE MONITOR OUTPUT TERMINAL SHOULD BE THE SAME TYPE AS THE TERMINAL USED FOR INPUT."
You cannot mix the HDMI with the others. You must therefore use the same on DVD and Cable box.
Best Regards and happy new year!
Charles
Jan 05, 2009 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
