Question about GE Energy Star WCVH6260F Front Load Washer
Wbvh5200j2ww my ge model wbvh52ooj2ww will ot work went thru cdes everthing works but not t10 spin ,ust 2 beeps. replace motor main board and water assembly. Please Help
  • 7 Answers
SOURCE: Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Posted on Oct 26, 2008
SOURCE: GE Model WSXH208-How do you know if PUMP motor is not working?
Found out the motor usually don't burn out that easy...therefore, I put it all back....let it run and felt the motor warming up....then it works....guess I was just a little antsy... ;=))
Posted on Jan 01, 2009
  • 512 Answers
SOURCE: GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Posted on Jun 12, 2009
GodBlessU
  • 3513 Answers
SOURCE: GE washer less than 2 yrs old won't spin or agitate
The agitator may be bound up. Remove the cap on it's top, than the nut or bolt which holds it inplace. Remove the entire agitator. Check for anything beneath it which may be causing the problem.
The belt may be too worn to grip the pulleys. Inspect it and replace it if there is any doubts. Easy to do and not to costly.
Also inspect the pulleys. They should rotate easily. If not, replacement may be the only opition.
Additional Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes, solving methods, part locations, disassembly, reassembly methods, repair procedures, pictorials, schematics, downloadable repair and or owners manuals which may be available online.
Another possibility may be to search the manufacturers web site for a downloadable version of the owners or service manual. The file will be a pdf file opened with Adobe which also needs to be downloaded but worth having the Adobe once obtained.
Retail appliance parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers. Appliance part stores and dealers are listed in the phone book.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, ideas, suggestions, test and or repair methods.
Use the reply button to add additional information or questions. Using this method moves the topic back up to the top of the list automatically.
Thanks for contacting Fixya.
Posted on Sep 19, 2009
SOURCE: GE Washer Spin Cycle Problem
I have a GE washer and my problem is that do the washing just fine. but when it goes for the rinsing won't take water. I have to pur water manually with a hose so it can go then to the spinning..
Posted on Nov 04, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Replace door gasket on GE wbvh5200j2ww
First of all, obtain a replacement gasket, then disassemble the door sufficiently to allow installation of the new gasket
Mar 23, 2013 | GE Washing Machines
My WBVH5200J2WW GE washer will not do the last spin cycle.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 24, 2011 | General Electric WBVH5200J Front Load...
I have a GE side by side GSS25JFMC. The freezer was left slightly open overnight. I noticed it this morning and closed it. When I came back, everthing was frozen up in the freezer so I removed panels and...
There is no reset on that model. I also don't think leaving the door open had anything to do with what happened. You will need to check both sides of the main control board located on the rear of refrigerator for burn marks or signs of heat damage. Part number WR55X10942
The main board does all the thinking on your refrigerator. Not many thing on that board that is not turned on or off. Unplug first and inspect board an let me know what you find. If board is OK then we will need to check the start relay and start capacitor down near the compressor. Thanks, Sea Breeze
Aug 20, 2009 | GE Refrigerators
My ge model wbvh5200j2ww washer wont't start. it has power on the panel but doorwon't latch or start filling.
If the pump filter is clogged, the washer won't even turn on. This filter is located behind the small access panel at the bottom on the front of the washer. Remove access panel, flip down scoop, and unscrew filter. You will need a bowl to catch water that comes out(may smell bad). Pull out filter, clean, and replace. Washer should work normally afterwards.
May 01, 2009 | GE Energy Star WCVH6260F Front Load Washer
Drum won't Tumble or spin
check motor winding resistance. new motor comes with motor control unit. main controls are not common on ge
Mar 08, 2009 | GE WBVH6240F Front Load Washer
Non-spinning washer
Have you checked the motor? Make sure that the motor is turning properly and also make sure that your belt it not to tight. It should have some give in it. If none of that works then look at the main bearing under the pulley on the drum
Feb 10, 2009 | GE WNSE6280BWW Top Load Washer
I just had a new GE washer delivered to my home today, June 24, 2008. All it will do is fill with water and than drain. The agitator cycle does not work and the spin cycle does not work. Model...
We had the same problem with our new GE washer.......the repairman just left. It's the circuit board on the motor that failed, causing the motor to stop working. GE will replace it under warranty.
Jun 24, 2008 | GE Washing Machines
GE Energy Star WCVH6260F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
