Audiovox lcd tv
After working fine for over a year, TV is displaying lots of green dots in areas that should probably be black. When cable box is turned off, screen that was previously black now has lots ov green dots/lines.
  • jabeebad Aug 28, 2007
    The same problem exists when watching DVD's, and also when viewing photos from a memory stick slot on the TV. I also tried using component cables from the cable box to the TV instead of the HDMI cable that I've always used. The model is: FPE2706DV.
  • 944 Answers
First easy thing to try is unplug the TV from the power for about half an hour and try it again. If no luck; Do you get the same effect if you unplug the cable box from the tv completely? what about if you are watching something from another source - DVD player or VHS or PC or similar. Do you get the same? Could you post back a photo of the green dots etc? may help us to diagnose the problem. Do you have a model number for your set - it doesn't seem to have posted? awaiting your info :)
Posted on Aug 28, 2007
  • Anonymous Sep 01, 2007
    You can get a user manual for the set if you need it on this link;
    http://www.audiovox.com/webapp/wcs/store...
    Unfortunately I couldn't see anything relevant in there, but you may spot something.
    All the info I could find (depends on exactly what the green dots look like) tends to indicate that the screen needs replacing, which is unlikely to be worth it - contact Audiovox first (details in manual) and check though - it may be feasible.
    Most likely cause is pressure on the front screen, or burn marks on the backlight diffusers.
    Sorry if bad news but I think it is probably irrepairable.
    Hope this helps :)
SOURCE:
I keep getting green dots all over tv screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 15, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Everything working fine, then home screen no longer displays on TV. On startup, pink dots go across TV screen, then TV goes black. Signal from most recent input is not coming trhough the audio or TV.
I have the same problem. I have an LG lcd tv as well. I have my cable box connected to via hdmi into the reciever then from reciever to the tv via another hdmi cable. I can watch tv and like the problem above see the pink dots on boot-up but I can't get the home screen to display.
Jan 08, 2013 | LG LHB975 Theater System
The tv is on, but the screen is black, no sound, etc.
if the green light is on your should have sounds if no screen,,try to connect your cable box if the sound is there you have faulty inverter board.
Nov 11, 2012 | Audiovox FP1500 15 in. LCD Television
Screen is all Green
New cable box recently? If not, your cable provider has probably pushed a firmware update to your cable box. Green screens are very common with HDMI connection. From your symptom, I am going to take a guess that you are connected via HDMI. If so, switch to Component cables and your problem is solved. It's not the TVs fault... cable boxes seem to be the single largest problem child for HDMI compatibility. I hope this was of some assistance.
Apr 11, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
Green lines in black areas
sorry to say your LCD panel is failing they are expensive , i hope your under warranty
Nov 23, 2009 | Televison & Video
Square box in middle of t.v. black everywhere else.
Turn off the closed-captioning. If it's set for text mode, the screen will blank out an area for the text to be displayed. On channels or programs where captions aren't being used you won't see any problems, but other times you'll have the mysterious black box. Many TV remotes have a single button to control captions, so it's easy to get into text mode without knowing it.
May 03, 2009 | Broksonic TV
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Mar 11, 2008 | Televison & Video
Televison & Video Logo
474 people viewed this question
Top Televison & Video Experts
Ekse
