Question about Whirlpool Washing Machines
Error code whirlpool induction
F25
SOURCE: F25 error code
this is scary. I got a brand new whirlpool duet sport I ordered from Costco.com. After 19 days of waiting for delivery it finally arrived and was installed by the whirlpool dlvy people. I read the instructions and started my 1st load within an hour of being installed. It never worked. Ok it work 6 mins and stopped on every cycle I put it on and then I got the error code 25. I called their customer svc number and they could not even tell me via the phone what that meant. I am suppose to have another delivered here HOPEFULLY next week but after seeing others having repeated problems I do not know if I should just say no take it all back.
Posted on Jul 26, 2008
huuum
  • 750 Answers
Hello twelsh2
Welcome,
You said, you started my washer and after a few minutes I'm getting this F25 code. Water starts to go in but it never starts washing. Any thoughts?
This is what F25 is telling you.
Condition
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down. If a failure occurs during high-speed spin, the door unlocks after 3 minutes.
Check and Repair
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power for 5 minutes (Rests the system)
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations
If you can not find the fault , Please call service.
We have service sponsors available in your area here in our web site if you need one!
Let me know what you find!
Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
blueextc3221
  • 15935 Answers
SOURCE: my whirlpool duet ht does not finish the cycle and
F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch.
The f25 error code is a motor tachometer error. To determine the problem you will have to remove the top cover and the front access panel. On some models, the rear panel will have to be taken off for easier access to the motor control. Now with the washer-unplugged remove the each plug one at a time and make sure the pins in the connector are not bent then reseat them on the board. Now retest the washer. If the washer still fails, you will need a meter to ohm the motor.
With the washer unplugged, locate the motor harness. Now unplug the motor connector to ohm the motor. Follow the list below to check the motor.
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
* Pin 4 to5 115 ohms
If the readings are close to what is listed above the motor is fine.
Live voltage checks are dangerous, and possibly deadly. Exercise caution at all times. If you are not comfortable working with live electricity I suggest you call an experienced service technician. I have provided you with a wire diagram with what the voltages should be. If the voltages are correct I would then recommend that you replace the motor control.
http://media.fotki.com/1_p,ssqftgqdqbftqgbxgtqsskgwtqkq,vi/sbbsgkqrgxstbrqrgwf/1/1303472/5961857/image5533851340308453439img-or.jpg
http://media.fotki.com/1_p,ssqftgqgtstgdfrxgtqsskgwtqkq,vi/wwkfkbqwwxkftrskdkw/1/1303472/5961857/image1769329000959650960img-or.jpg
http://media.fotki.com/1_p,ssqftgqbrdddksdxgtqsskgwtqkq,vi/stbrqrgwfxsbdkgqfbr/1/1303472/5961857/image5269611314094350944img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washer wfw8400tw codef25
* Pin 1 to 3 6 ohms
* Pin 1 to2 6 ohms
* Pin 2 to 3 6 ohms
Posted on Sep 28, 2010
Code F25 on my whirlpool washer
F25 is a MOTOR CONTROL error . check for past posts in Search as there were some in 2007 shown on Fixya . or check throgh Google / Internet explorer by stating F25 Washing Machine error
Jan 09, 2018 | Whirlpool Washing Machines
Whirlpool Duet Washer error f25
have whirlpool duet washer showing f25 code checked all connectionshave bare wires showing on rpm sensor on end of motor separated them and still showing code what else can i do
Oct 28, 2017 | Whirlpool Washing Machines
My whirlpool front load washer will not spin out. its showinf error code F25
According to the tech sheet, F25 indicates a possible drive motor tachometer error. (NOTE: The tech sheet is located behind the front quarter panel- remove the three hex head screws at the very bottom to remove the panel. The tech sheets will be folded up in a little plastic pouch. Since there a various reasons for your problem, I just can suggest starting point since there is a code displayed.
Dec 23, 2016 | Whirlpool Washing Machines
Whirlpool duet sport error f25
F25 is a communication error between the mcu(motor control
Nov 05, 2016 | Whirlpool Washing Machines
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 | Cooktops
Fault code F25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
I got this working for many on this site :)
Thanks
Fame !
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F25 error code
Jan 27, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
