Question about Water Filters & Coolers
Ge gxrm10gbl o2
A months ago, we changed the two filters out and all was fine - then about 10 days ago, the pressure became less and finally there was no more water in the tank. Do you have any idea where we need to begin looking for the problem? Thank You, Lisa lisa_92867@yahoo.com
3 Suggested Answers
FreshWaterSy
  • 13 Answers
SOURCE: I have a ge reverse osmosis filtration system and
Make sure that all valves are in the open position.
Try to recharge the water storage tank. Here are the steps to follow.
* In General: When any type shut-off valve handle is positioned so that it is parallel or in line with the tubing that enters the valve, valve is OPEN. When handle is turned perpendicular to tubing that enters valve, valve is CLOSED.
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO system tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this
procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
www.FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on May 01, 2009
SOURCE: GE smartwater R.O. system leaking out weep hole
Same exact problem started for us last night. (Same model, installed by me about four+ years ago) Water was really coming out of the weep hole, and didn't stop until I shut it off at the valve. This happened once before, and all I had to do was clean the drain line adapter, because it gets full of gunk from the disposal over time. But this time that did not do the trick. (Plus there was not all that much gunk this time....) So I was baffled for awhile but came up with this solution.
I hooked up a small length of clear tubing to my cheap-o tire inflater/air compressor. Put the clear tube against the weep hole. Turned on the compressor, and VOILA!, a bunch of gunk that was clogging the drain tube came out. I think when this tube, or the drain line adapter gets clogged, it causes water to go out the weep hole instead of down the drain. (If you don't have a small compressor, then theoretically there is enough air pressure from something like a bicycle pump, and this solution *might* work with one of those. But if you try this, of course only use the DOWNWARD (air-going-outward) pump action...pulling up (inward) would force the clog deeper up the drain tube)
Posted on Oct 02, 2009
My 2000 s-10 2.2 cranked fine this morning. But when i went to take off, none of the gears worked. The selector moves, but you dont feel it going into any gears. The trans has just had filter and fluid...
If the transmission fluid is full and the linkage connected then you have but one choice here the transmission has failed. I have seen this exact scenario come through the door of the shop dozens of times, drove fine then nothing the next day or an hour later or 10 minutes later. The cause, a faulty clutch pack or a failed hydraulic pressure pump or a internal leak in the high pressure fluid circuit that applies the clutch packs.
Feb 07, 2012 | 2000 Chevrolet S-10
2001 S10 4.3 vortec 4x4. 230k Fuel pump and filter changed about a year ago. Plugs and wires change 6 months ago. The truck is very sluggish when accelerating, to the point where if I continue to depress...
it could need a fuel injector cleaning or replacement if an injector has a problem.check the air filter as i`v seen them so plugged to cause this type of problem.there could also be a problem with the throttle position sensor(tps)not sensing the proper voltage increase when moving the throttle.i guess you installed a new fuel pump not a used pump but sometimes even a new pump is defective and the fuel pressure and volume should be checked.it`s also possible the catalytic converter is plugging up and needs to have the exhaust back pressure checked.at idle the pressure should be less than 1lb pressure and at 2,000 rpm`s should be less then 2.how dirty was the filter when it was replaced it could need changing again if there is alot of dirt in the fuel system.
Apr 01, 2011 | 2001 Chevrolet S-10
1999 Jeep Grand Cherokee / Approx. 133,000 miles - Owned since new and very well kept. Only at idle, engine stops working but would start again after 20 min wait, would work fine for a few days and do it...
I would try your pickup coil in your distributor. I would also be checking the o2 sensors. both of these things can cause problems like this and would not set off the check engine light.
Nov 16, 2010 | 1999 Jeep Grand Cherokee
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
GE side by side refrigerator water dispenser slow starts.
Well, the age doesnt help it, but have you ever changed the filter and had it all cleaned, if not all must be cleaned and filter changed, that should do it
Feb 09, 2010 | GE GSH25JFR Side by Side Refrigerator
Why is 99 mercury cougar getting bad gas milage"It seems to be getting worse.Less milage than my 99 ranger4x4.new plugs,oil change about 2 months ago.would a new O2 sensor help?
Try new plugs, wires, fuel filter, air filter, pcv valve, and if its still not too
good,, do the 02 sensors..
Have a good day !
Oct 24, 2009 | 1999 Mercury Cougar
No water pressure
I can send you a repair manuaql if you like. You also can just ge a prefilter from lowes or home depot and just bypass the filter ion your fridhe. I know about the water there. Live there for six years. Thanks Sea Breeze
seabreezehvac@yahoo.com
Mar 23, 2009 | Maytag MZD2766GES Side by Side...
GE smartwater under sink filter shuts down after changing filter
run water through the unit with no cartridge in place. Then check the filter to be sure it does not have an obstruction in it. Finally, replace the filter and your pressure should be fine. Good luck.
Jan 19, 2009 | Home
Water Filters & Coolers Logo
95 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
