Question about Canon Pixma MP500 All-In-One InkJet Printer
White streaks, no color, fragmented
I have read and reread and done all the tests and cleaning possible, but still have white streaks through the black (about 1/8 inch wide) and other colors are not showing up. All ink levels are full. When I run the nozzle head check and print alignment, only a fraction of the first top line came out -- no color, not the whole pattern. Yesterday the printer worked absolutely perfectly. The manual gives me no more ideas on what to do. When I go to HELP menu on Pixma it says "no help available." Help please. I have a Mac OS 10.3.9
  • 1 more comment
  • Virginia Leslie Aug 29, 2007
    In addition, I have downloaded and successfully installed the newest driver from Canon. Still no color and white horizontal stripes.
    I might seek your help, IF I know I am talking to someone who knows Mac as well as the PIXMA. Too often there is not sufficient knowledge base of Mac systems.
    Yea! A happy ending. I was talked through removing the print head (not sure why that isn't named as a next step in this problem in the user's guide) and there was a piece of paper stuck to the bottom of it. Once removed and with a few more cleaning runs, it is back to normal!
    I should have posted my last entry as a solution. Anyway, it was a torn piece of paper stuck to the bottom of the print head. Once removed, all is well.
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
  • 2692 Answers
SOURCE: my canon pixma doesn't print well with my new windows vista
Download  and install the updated VISTA software for your model printer See link below:
Posted on Feb 18, 2009
  • 5 Answers
SOURCE: Cannon IP4000 PIXMA - pink & green streaks
I've had the same problem with my ip4000, but the solution was to get a new print head. They can be quite costly, so I recommend the following:
1. Contact Cannon support and see if you can get them to send you a replacement. They sent me one free of charge, and didn't need an RMA for the old one, so it was hassle free.
2. You can always try to aggressively clean the head yourself by removing it and following some of the "home brew" procedures others have tried. However, you can damage the head further this way and it's only a last resort. Warm distilled water and a syringe was used by one person. When I tried this, it did not work at all, and I called Canon for the replacement anyway.
Posted on Feb 24, 2009
  • 85 Answers
SOURCE: Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Posted on Feb 26, 2009
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
C252 streaks
Check your consumables. Press utility then check consumables. If anything is at the end of life, it needs replaced. It sounds like your drums are not cleaning properly and need to be changed. If they are fairly new, then I would suspect the transfer belt. If you know hoe to get into service mode you can go into test mode. Then run your halftones on each color. If it moves around, its your drums. If it stays in one spot, its your transfer belt. Also you could check your drum units. If they have streaks going across the green drum, like its dirty, then its coming from the drums.
Apr 17, 2014 | Konica Minolta bizhub C450P Laser Printer
"Check Color Cartridge" displays even after replacement of cartridge -though I don't think original cartridge was empty- and stops printer from printing. The new cartridge is installed properly, and...
  1. First, check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges.
  2. Second, make sure your paper is not causing the problem. Paper that does not accept ink well can cause your images to smear or bleed. Plain paper is not the best choice for high-density graphics. Click here to see how to pick the best paper for your project .
  3. If the paper is not the problem and you are using genuine HP cartridges, print a clean test to see if the printer and cartridges are functioning properly. Load the printer with clean, plain, white paper and print a clean test page. To see how to print a clean test page, see your printer's User's Guide , or see HP Deskjet Printers - How To Print Internal Tests , or HP All-in-One Product Family - Printing Self-Test Reports .
  4. Evaluate the clean test page. Different printers produce different pages, but you should recognize elements from the examples below on your test page. In general, cartridge and printer problems are indicated by streaks, missing colors, or wrong colors.
    • Examples from a good printer and cartridges (your test page may not look exactly like this): Figure 1: Solid colors that match color dots on cartridge labelc00059224.gif Figure 2: Pattern unbroken, or broken in only a few placesc00059225.gif
      c00059227.gif If your test page looks more like the good examples above than the bad examples shown in the next two sections below, the printer and cartridges are probably not causing the problem. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - streaked or broken bars or lines Figure 3: Fading, missing, or streaked bar - low-ink or empty cartridge, clogged nozzles, or electrical problemsc00059228.gif
      Figure 4: Color completely missing (magenta bar missing below)c00290898.gif Figure 5: Lines broken randomly - clogged nozzlesc00059231.gif
      Figure 6: Lines broken in pattern - dirty contacts or other electrical problemsc00059232.gif
      Figure 7: Color completely missing (magenta pattern missing below)c00290899.gif If your test page looks like these examples, you probably have a cartridge that is empty, has clogged nozzles, or dirty contacts. Click here to continue troubleshooting .
    • Examples from a failing printer or cartridges - colors do not match the color dots on the cartridge label (Note: do not compare the test page colors to the colors of the examples on this web page. Your monitor may not display the colors properly). c00059234.gif c00059235.gif If your test page looks like these examples, you probably have a cartridge in which the inks have mixed. Click here to continue troubleshooting .
Oct 26, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
My printer is running a white streak through the center of pages
You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
Color print is streaked. I've done the clean
if its white lines appearing in the printout then its sirely down to air, you may want to replace the cartridge with a new one & perform a few head cleans one after another.
see if that cures it for you.
Aug 09, 2009 | Epson Stylus Color 740 InkJet Printer
Magenta leaving a colorless streak
You need to check with Xerox , ther is some toner that was manufactured last year (2008) that was defective
the phone number for xerox support is 503-682-7377
Apr 01, 2009 | Xerox Phaser 7760/GX Laser Printer
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
My Canon i960 printer is printing red streaks on the pages
It's possible that the heads need to be replaced. That's one disadvantage to the printers that don't have the heads contained within the cartridge.
Feb 26, 2007 | Canon I960 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
67 people viewed this question
old marine
old marine
