Question about Sharp Microwave Ovens
What is the cubic foot capacity of sharp model r-1471
Microwave built-in yr-1996 what is the cubic foot capacity of sharp model r-1471
MicrowaveSvc
  • 9047 Answers
SOURCE: Cubic size of Goldstar MA-1160MW
You can figure the cubic feet with this handy calculator.
Posted on Jan 29, 2009
najah
  • 180 Answers
SOURCE: where is the monitor switch on a sharp r-1471
You can check the protection diode fitted across the highvoltage capacitor near to the Highvoltage transformer. If it is shorted there is a chance to blow off the fuse. There is no chance for the monitor switch. Any way you can check the monitor switch which is located near to the control panel( Near the door switch)
Posted on Jun 04, 2009
SOURCE: Metal plate on inside of microwave has hole & is arcing.
The Arcing is a real bad sign, and you see the "Brain" has detected a fault condition, most likely the Power Supply and or magnetron, or High Power Diode, has "Faulted" and it shuts down for Safety reasons. Due to the danger existing inside MW, I recommend that you have it serviced by a qualified person. Always get a firm "Quote" before proceeding with any work. Be careful, as often a repair may cost as much as a new one.
Posted on Mar 13, 2010
Testimonial: "Thanks for the insight. We will definitely look into the items listed and have it looked at by a qualified repair tech."
jsrock516
  • 5911 Answers
SOURCE: 15 year old sharp carousel
If everything works, but the microwave oven does not heat, this is commonly caused by a failed magnetron. The magnetron is essentially, the heart of the oven that produces the RF energy that is used to heat your food. In order to replace a defective magnetron, you will need to consider the following:
1. You will need to uninstall the oven from over the range in order to replace the part (you will need to do this anyway, if you decide to buy a replacement oven).
2. Ensure the oven is UNPLUGGED before servicing anything inside the cabinet and remove the exterior case in order to access the magnetron. There are several websites that you can use that illustrate how the oven is assembled:
searspartsdirect.com
pcappliancerepair.com appliancepartspros.com
NOTE: If you've never repaired an appliance on your own before, a microwave oven is usually not a recommended appliance to start with. Some models can be rather involved in taking apart.
3. The magnetron replacement part number for the model you have listed is 505137 and is listed as item 1-12 in the parts index. It costs about $100.
4. This model also has a thermperature fuse, listed as item 1-10 that can also cause the same symptoms if blown. The fuse is essentially a thermostat acts as a fuse if the oven cavity overheats. The part number is 46-1518457-3. You will need to remove the thermostat from the oven and take a resistance check across the component terminals to determine if it is good or not. A low resistance reading indicates a good thermostat. An infinite reading, indicates a blown thermostat and needs to be replaced. The average replacement cost is about $10. I would recommend you check all fuse associated with the oven before assuming the magnetron has failed.
Review the parts illustrations at the recommended websites to see if this is something that you may be able easily take apart and reassemble.
If you have any questions, please post back and let me know. I hope you find this information helpful.
CAUTION: DO NOT operate a microwave oven with the exterior cover off. The voltage inside the High Voltage network where the magnetron is installed can exceed 3,000 volts!
Posted on Dec 26, 2010
woobie dog
  • 1273 Answers
SOURCE: We have the GE JVM130H
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Posted on Mar 19, 2011
What is the Interior Cubic Foot capacity and the wattage of my GE Profile Microwave JE1540WW02?
GE oven model JE1540WW02 has a capacity of 1.5 cubic feet, and cooking power of 1000 watts. The power is listed on page 14 of the owner's manual here.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | GE Microwave Ovens
What is the cubic feet
cubic feet is the measure of volume. one cubic foot is 1x1x1 foot. the size of the microwave varies with MAKE and MODEL. but is normally in the range of 1 to 3 cubic feet
Oct 25, 2015 | Microwave Ovens
I need to replace my over the range GE microwave Model # JVM1330WW002 and don't know what size/capacity it is?
Get cubic foot size by multiplying height x width x depth.
Divide that by 1728. If oven is 12 x 12 x 12 then it's exactly 1 cubic ft.
If 6 x 6 x 6 then it's 1/2 cubic ft or. 50 cu ft
Nov 28, 2014 | GE Microwave Ovens
Sharp R-1461a. What are dimensions?
The dimensions of your Sharp microwave model number R-1460, R-1461 and R-1462 are 29 3/4" in width 14 3/4" in height and 12 1/2" deep. Capacity is 1.1 cubic feet.
Sep 30, 2013 | Microwave Ovens
Model 56-4677
Measure the width, depth, and height in inches of the interior cavity.
Multiply the length by the width by the height to get the total in cubic inches.
Divide the cubic inches by 1,728.
The resulting number will be your microwave's capacity in cubic feet.
Jun 05, 2013 | Microwave Ovens
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Mar 19, 2011 | Microwave Ovens
No power at all - breaker is on
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 07, 2010 | Sharp KB6015 Drawer 24 Inch Wide 1 Cubic...
Just wanted to know the size of the GE profile microwave model JVM1660BB005. Is it 1.5 cu ft? Looking at a new model JVM1540LNCS to replace it and want to use the same mounting hardware.
In GE microwaves, the first 2 digits of the model number are the cubic footage. 1660 is 1.6 cubic foot, 1540 is 1.5 cubic foot. Take care trying to use the existing hardware, the exact placement of hardware and upper installation screws may vary from year to year or model to model..
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
What is the cubic feet of a model 25353614300 side by side please.
This should be a 23 cubic foot Frigidair built refrigerator. The actual dimensions usually are 22.4 cu. ft. Sears keeps changing how their model numbers read so I could be wrong. Good Luck, Appliance Specialists
Dec 17, 2009 | Microwave Ovens
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
