User code.. i have a problem in copier model : nashuatec 3237 when i start the nachine it shows me code... "U_2" i look in the table and it mean : "set kay counter correctly or enter your user code"... what is it?.. i dont have user code... help a anybody. :|
user tools>system settings>admin> address book then select the user and you can scroll down or goto authentication and change the password. if you cant get into admin try the username administrator with no passowrd or service with no passwrd
Hi, in order to activate the double count for A3 paper, you have to go into "special" SP mode. The procedure is almost the same as going into regular SP mode, but as you hit "Copy SP" on the touch screen, make sure you are holding down the pound (#) key. Then you should be able to find 5104.
You can only change 5104 once, so one you enable it you won't be able to change it back to counting larger paper as 1 click instead of 2.
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
