JVC Ax-r562 intermitant source selector - Audio Players & Recorders
2 Suggested Answers
Mosaub
  • 65 Answers
SOURCE: when turning the source selector
remove the front panel and if you have clear alcohol and just few times over the SW and turn it around that's all
just tell me if it work
Posted on Aug 05, 2011
Jvc ax 444 amplifier
http://uk.jvc-service.net/webtemp/AX-V55.pdf?CFID=15017492&CFTOKEN=79974873
This model is the nearest one I can find, but most amps from the same manufacturer use common parts and circuits.
Jul 13, 2014 | JVC Televison & Video
JVC Ax-r562 sound is gone for a 1 sek or 2
On all inputs? Tuner, and AV inputs, a box of any kind can cause this, check with a DVD etc.
Jul 14, 2013 | Televison & Video
Wipers work intermitently
Contact's in wiper switch worn or corroded! Replacement needed is it a ford? Or Toyota? :)
Jan 24, 2013 | 1997 Ford Taurus
When turning the source selector on my AX-596, is sometimes takes a couple turns for it to change source. Is this an easy fix? dirty switch?
Aug 03, 2011 | Yamaha AX-596 Amplifier
MANUAL JVC AX-90
what is this.....
ðóêîâîäñòâî JVC AX -90
take it to the service center...
Jul 11, 2010 | JVC Audio Players & Recorders
Hello i was wanting to know if i could hook up my AX-596 amplifier to my Yamaha HTR-5860 reciver
I assume you want to slave it to the receiver and drive some more speakers with it.
Connect some RCA cables from whichever channel pre-outs you want on the HTR-5860 to any input on the AX-596.
Set the AX volume to something sufficiently high, run through the HTR's speaker level setup and match the AX volume to match the channels on the receiver. Then leave the AX's volume alone.
If you just want the AX to have access to program sources of the HTR, run the RCA cables to it from one of the VCR1 or 2 Out (but DO NOT select whichever one you use via the front panel). These are not affected by the HTR's volume controls.
May 07, 2010 | Yamaha AX-596 Amplifier
I want to connect YST-Sw1500 sub woofer to the AX-596 amplifier .How can I do the connections .
on ur subwoofer u will see HPF output, connect this output to MAIN IN of ur power amp (first remove jumper between pre-out and main in from ur power amp) connect pre-out of ur power amp to input 2 L&R (Left is also for mono input). the HFP selector switch will cut off 80Hz or 100Hz to the main input depending on the position enabling u to have high frequency sound on your main speakers. connect the speakers to the main output terminal of ur power amp. do not connect speakers on the woofer ouput.
make sure u are using the right impedance speakers. do not switch speaker impedance selector while the unit is on.
Apr 04, 2010 | Yamaha AX-596 Amplifier
JVC AX-66 Integrated Amplifier seems to be muted?
You need to have a jumper between the 4 standalone jacks on the right side of the column of stereo connectors. A stereo RCA cable would work for this.
Oct 14, 2009 | JVC Audio Players & Recorders
I am trying to connect my Samsung 56" DLP HDTV to my JVC THD50 home theatre system, all the speakers are hooked up correctly but I can't source from the tv to the speakers correctly, I connected a...
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Apr 03, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
