Question about Panasonic TC-P50GT30 50" 3D Plasma HDTV - 1080p
Panasonic TC-P50GT30 went dead
I had just turned on the TV and there was a small click and then the TV went totally dead. I have no unplugged it and will do so for an hour then try to replug it. (One hour passed) I tried to turn it on..... Now the red Light Blinks 7 times. TV still does not work.
SOURCE: TV Won't Turn On
I purchased the TV using AMX card 18 month ago. They have an extended 1 year warranty on top of manufactory's. I just have this set repaired: replaced SD board, total charge is $550. I already file a claim and hope to get reimbursed soon.
Posted on Mar 06, 2008
tvguy171
  • 106 Answers
SOURCE: Panasonic TH-42PX80U won't turn on.
You are missing 15volts. If this is a new TV, it could be as simple as a plug not fully seated on the power supply. Regardless, the repair should be covered by warranty and Panasonic is one of the best when it comes to taking care of the customer. Ifd nI can be of further assistance, let me know
Posted on Dec 21, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
  • 8457 Answers
SOURCE: when turn on tv goes to stand by mode and light
Ur tv power supply board it defective,it have dead parts call capacitors.U know basic electronnic's and soldering?Take ur tv aparts,where the a/c power cord go into it.That ur power supply board,searches all around the power supply board and it supporting boards.Look for these dead gases leakage capacitors,they all have bulges on it top or puff up on it top.Replaced these dead gases lekages capacitors,will get ur tv power back,stable and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on May 12, 2010
RixsFixes
  • 2200 Answers
SOURCE: panasonic hd tv light blinks 7 times
Unfortunately this appears to be a common issue developing with these Panasonic sets i.e the '7 blinks of death'!
Several customers are complaining about it. The problem is caused by one, both, or all of the following boards: SC board, SD board, and SU board.
Most commonly, the SC board is the one that has failed and because Panasonic have received so many complaints about this issue they are now agreeing to replace the SC board under extended warranty.
However this is not widely known amongst the general public and Panasonic have kept it very quiet.
I would suggest that you make contact with the Panasonic Concierge service centre. Make them aware that you are aware of the SC board issue and that there is an extended warranty on this and ask them to replace it.
However if it happens that one of the other boards has failed be aware that Panasonic are not covering these under warranty and you will be charged for the repair in this case.
The Panasonic Concierge service is available from here
Thanks for using FixYa.
Posted on Jul 09, 2010
My Panasonic TC-P60ST30 will not power on. It makes a click sound but will not power on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 28, 2016 | Panasonic TC P60ST30 60 Class VIERA ST30...
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Won't come on after power outage
hi is it totally dead if so it's possible the fuse inside could have blown, this will be on the power board, glass type, if it has and you replace it and blows again then there's a dead short on the power board or on main board hope it helps
regards
shaun
Dec 30, 2013 | Panasonic TC-P50X5
We just purchased a vieja TC-P50GT30 and we can not get the audio to work. Please help
Good day!!!!
Please try to play a DVD or any movies to your TV to determine weather the problem is on the TV itself or on the signal reception or on the digital cable box..
If the TV have audio when you play a DVD your TV is good..
Possible problems are:
1. loose wiring on antenna (coaxial)
2. digital cable fault contact your provider for immediate remedy
3. bad tuner.
Hope it helps..
Dec 02, 2011 | Panasonic Televison & Video
Panasonic viera TC-P50G15 tv cut off in the middlde of watching it, red light kept blinking on tv, dont recall how many times, unplugged tv then plugged back in at that point no lights came on & tv...
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 22, 2011 | Panasonic TC-P50G15 50 in. Plasma HDTV
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic TC-P50GT30 50" 3D Plasma HDTV - 1080p Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
