Eee pc 1000HE Ac Power/Battery flashes on screen nonstop
My girlfriends netbook, stated above, keeps flashing between "ac power" and "battery" over and over. I'm wondering if her battery is going bad. Or if it's perhaps her charger. The charger seems unlikely as it was just replaced not but two weeks ago. Thank you for your help.
    Master:
  • 663 Answers
I suggest that you remove the battery from the computer and use the charger only to power up the computer and observe if it does the same thing. If yes, then you might want to update the drivers in her computer. Try using RadarSync.
On the other hand, if the computer turns off with the charger only, then you need to buy a new charger. You can also try using the battery only and check if it goes off.
What you have to try is to isolate the part which causing the issue by trying them one by one.
David
Posted on Jul 15, 2013
pontelemon
  • 538 Answers
SOURCE: laptop wont boot and the battery and power lights flash
"......no beeps and it is a 3rd party charger for this model of laptop."
That 3rd party adapter could be the problem. Also, try to take out the battery and power it up from AC adapter only.
Ideally, try to find original AC adapter just for testing.
Posted on Apr 16, 2009
  • 130 Answers
SOURCE: Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Posted on Jun 21, 2009
pumpkinman
  • 1165 Answers
SOURCE: Gateway MA7 (MX6955) Will not boot up, or power
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Posted on Oct 08, 2009
  • 20 Answers
SOURCE: My eee pc wont recognize that it is plugged in.
Usualy this is a battery fault.
If the laptop remains on ac mode without battery try to replace the battery.
Posted on Mar 10, 2010
  • 206 Answers
SOURCE: AC Power supply overheating for ASUS eee PC
If the pc is fully charged, dont leave it plugged in. Mine gets hot but I've experienced ones that were hot to-the-touch...I'd say be careful leaving it on charge when you are not at home.
Posted on Jun 09, 2010
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
While using my Asus Eee PC netbook on battery mode, I lost all power. When I plug it in for ac mode, the power comes back up and the screen gives choices of "safe mode", or "start windows...
Obviously there is a problem with either with you battery or charging section of your laptop, first you check your battery is charging or not, also check by replacing a new battery,,,,
rate me if found usefull
Aug 27, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have Asus Eee 1005AH. Only starts up if I remove than replace the battery. I have to do this every time I want to use the netbook. Please Help!!
Take out the battery, and unplug the AC adapter, so there is no power to the computer. Then, press and hold the power button for about 30 seconds. This discharges small capacitors inside of the computer, which are like mini batteries that keep things running smoothly when your power source isn't the highest quality, like from the wall. Hopefully this solved your issue!
Aug 19, 2011 | ASUS Eee PC 1005HAVU1LBK Netbook PC Atom...
Power on then blank screen with an underscore on left corner side.
try un plugging the power cord and battery from the netbook , then press the power button for 5secs. then place back the battery and try to power it on with the power cord connected.
Aug 13, 2011 | ASUS Eee PC 1000HE Netbook
Can i use my asus netbook while charging it or plugged in with the battery?? will it affect the battery or not?
Hi dimarananjom,
That is fine as long as you will be using the machine like for watching Movies or playing games ON line or OFF line or maybe playing audio for 30 mins to more than an hour, but if you will just be using the machine for typing in a document or or maybe creating a resume using word then I suggest that the AC Adapter be unplugged this is to maintain Battery Life instead of having continuous power which can exhaust the battery cells faster.
Again if the usage will be something that may require more power like watching a move and highend stuff it is OK with the adapter plugged in but if the usage will be something basic use the battery alone this will be better for the battery life to last longer.
Jul 11, 2011 | ASUS Eee PC 1000HE Netbook
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
Mar 09, 2010 | ASUS Eee PC 1000H Netbook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
