Question about Garden
Atco admiral 16 s
My Admiral 16 starts OK but then stops almost immediately. Plenty of fuel and spark plug must be OK for it to start. Help?
    Master:
  • 969 Answers
Check for low oil level. 30w oil.
Posted on May 28, 2014
jj505
  • 195 Answers
SOURCE: Yard-Man Mower model 418D401 doesn't start
Need to remove carberator bowl nut and bowl and activate float to smell new gas coming thru,stuck mostlikey due to storage.
Please rate. Thanks. jj505
Posted on Mar 30, 2009
wilsodfarm
  • 986 Answers
SOURCE: my wtd yard machine will not start on first try.
Sounds like you have a bad conection on your solinoild(are your battery conection tight) does the engine turn over by hand ok.clean all your large wires and that the grounds too.I think you will find your problem by cleaning,
Posted on Sep 14, 2009
  • 62 Answers
SOURCE: engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
Posted on Sep 19, 2009
  • 3 Answers
SOURCE: Mower will not start. Have gas, air, and spark.
I am assuming this is a newer mower troy with a brigs on it, that being said there is a small plastic tube (intake tube) on the other side of the carburator that you can acess by taking the heat sheild off of the front of the mower. These are natorios for cracking or braking which would cause a huge vacume leak and a no start condition. They are about 10 bucks and take 10 min. to replace.
Posted on May 23, 2010
  • 173 Answers
SOURCE: four stoke mower. Mower starts and runs ok but
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Posted on Dec 28, 2010
How do i undo the blade on my atco admiral 16 lawnmower
Remove center bolt holding blade in place.
Aug 02, 2016 | Garden
How do I fix the key ignition on an Atco Admiral 16?
Unless you have electrical experience, I suggest have it done by a pro for safety and fire reasons.
Nov 07, 2015 | Garden
How to fix atco admiral 16
what is problem
Aug 27, 2014 | Garden
Atco admiral 16 s
open the remote control and clean the keypads contacts, from dirty+corroded+bad contacts, use contacts cleaner solvent.
Use the digital camera or webcam cell, the LED must be TURN ON, otherwise proceed as indicated see the picture.
Jul 14, 2013 | Televison & Video
Starting problem with admiral 16SE Petrol lawnmower
lack of fuel
possible water in the unit or blocked main jet
have the carby overhauled
Feb 08, 2018 | Admiral Garden
I have an admiral dryer that has now power when the start button is pushed. The breaker is good. I replaced the door switch, high limit switch and thermostat , still know power.There is know buzzing a
That must be the motor is bad if you have already detirmined the fuse mounted on the heater is ok. Buzzing usually indicates a motor poling out.
ADMIRAL DRYER SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2012 | Admiral Dryers
How do I use the self cleaning feature on an old admiral stove? I cannot find the manual.
CLICK HERE for the manual
HOWEVER - I recommend NOT using this function - as this takes many components out of their normal heat range, and can cause damage/repairs.
The Self -Cleaning section starts on page 16.
Thanks!!
Aug 05, 2011 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Admiral washing machine will not start
admiral washer machine will not start and before it died there was a weird noise coming from the machine.
Jun 28, 2010 | Admiral AW22 Top Load Washer
Garden Logo
142 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
