Air conditioner e4
Troubleshooting york hvac ac after 30 mintes E4 error code
bobotfel
  • 236 Answers
SOURCE: WRAC has E4 on display
E4 means return air sensor error, if the error cannot reset may be the return air sensor is out of range or defective. But if the sensor is ok you need to replace the control board itself. The reading of return air sensor is 8k to 10k ohms @ 25deg. C temperature.
Posted on Jan 13, 2008
SOURCE: E4 Error code on APE07AHM1
I emptied the water tray. Viola!
Posted on Jul 17, 2008
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
SOURCE: E4 error message on Dimplex portable air
Ensure water emptied
Posted on Nov 02, 2009
  • 57 Answers
SOURCE: I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Posted on Jul 16, 2010
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
What's the means of E4
I don't know what model you have, but maybe the error codes are the same for all air conditioners. Check here:
http://acerrorcode.com/york-air-conditioner-error-codes.html
Nov 16, 2014 | Heating & Cooling
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
E4 error on Yamatsu S-24H air conditioner ?
E4Fault indoor coil sensor (open or closed). Replace it.
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
19 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
