Question about Panasonic CT-27G13 TV
Ct-27g14 looses picture-comes on if you wiggle the wires on front
The plugs on front where you can plug in a game. When we loose picture we wiggle the left connector and the picture comes back on.
  • 398 Answers
See other post.
Posted on Aug 28, 2007
SOURCE:
If my cel keeps coming on and off every couple hundred miles and it read the sensor on the bank 2 convert and if i goe and wiggle it around it goes rite off what can i do too make it just stay
The fault appears to be in the plug. First thing to do is take a picture of it for future reference. Second disconnect the sensor and look at the plugs, if it is the sensor side plug that is damaged yes a new one will fix it. However if the engine side plug is damaged you'll probably have to get a new plug. However the plug pins may just be loose, or have a faulty connection between the wires and pins, which could probably be fixed by soldering the wire. Lastly the spring terminals in the receiving side may be loose or broken, they may can be bent back into shape so they make constant contact.
Jul 10, 2014 | 2000 Dodge Intrepid
Panasonic CT-27G14A
Have you tryed both the front and the back inputs?
May 17, 2008 | Panasonic CT-27SL15 27" TV
My Bajaj boxer CT doesnt start when I kick start it for the first time in the day. It starts only by pushing the vehicle and releasing the clutch in any gear. The subsequent kick starts are good though....
Hi, Cloud and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Fix Chinese 49cc Scooter that won start
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 24, 2014 | 2005 Bajaj CT 100
I have a Panasonic CT-34WX50 HD CRT. Lately the RED has been missing from the picture, usually when I first turn it on. Sometimes it will come back by itself, and sometimes a light smack to the side of the...
Check the video output card, at the back of the picture tube, for any loose solder terminals. Re-solder all the suspected terminals by applying a little more solder to each terminal, without making any solder bridge short in between adjacent solder close solder terminals. Loose contact to this card is the problem. The card can be located directly plugged on to the back of the picture tube. Its solder side is exposed before you, when you open its back cover. Do it. This is not a skilled work.
Feb 11, 2013 | Panasonic CT-34WX50 34" TV
My ct 100 doesnot start .No current in spark plug .All other accessories like head light etc work on kicking the bike.
Hi, Nalinchawda if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
Chinese scooter no spark kit
Madass No Spark Test Part 1 wmv
Jul 14, 2011 | 2005 Bajaj CT 100
Remote sensor on Panasonic CT-27G14 not functioning. How can I fix it?
firt try with your cellular, put your cellular in camera and put your remote control in front of your cellular and press one botton, if you see a blincking ligth, your control is good and your IR sensor in the tv is bad.
Apr 25, 2010 | Panasonic CT-27G14 27" TV
Our Panasonic tv is about 8 years old and will cut off by itself and a few minutes later it will come back on. Some days it is worse than other days. Please advise what we need to do. Thanks, T. Gibson...
The first thing you can do is try plugging it somewhere else. Sometimes its the wall outlet. Unplug it and check to see if the plugs don't wiggle. Sometimes the metal plate on the plugs has broken loose. While it is plugged in move the cord to see if it does it. When all that don't determine the problem. You can open the TV, and check for loose connection, and cracked solder joints. Look aroun the flyback area because thats where most cracks develop because of its weight. I really don't recommend opening the TV because you could make the problem worse if you are not carefull. Also the tube can have lethal charge even if not plugged in, and some TV this charged remain for up to three days. Good luck.
Jun 27, 2009 | Panasonic CT-32D12D 32" TV
PANASONIC CT-27D30B
Maybe the vertical IC output are damaged you need to replace him
Sep 19, 2008 | Panasonic CT-27G14 27" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Lose vidio
The solder joints on the vertical output IC have come loose. This is very common on those sets. If you do not have any experience resoldering small parts on PC boards, have the IC resoldered by a qualified tech.
Aug 27, 2007 | Panasonic CT-27G13 TV
Panasonic CT-27G13 TV Logo
51 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
