Hitachi l32h01ua Flicks to blue screen with HDTV sky connection intermittently. The only happens for a few seconds then returns to picture. All sky equipment including Hemingway cable have been changed.
techman
  • 3130 Answers
SOURCE: toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
epik559
  • 44 Answers
SOURCE: screen turning blue now and then on various channels
Picture tube issue. How long have you had it? Call the manufactor.
Posted on Jan 03, 2008
daniel719
  • 240 Answers
SOURCE: picture flicks on and off
remove back panel of set look at the pcb boar conecting to the crt, look for a wite or black ajustment knob not all sets have them but most do, it called the g2 seting turn up your g2 a bit pic should come back the sad thing is this meens you pictortube dosent have much life left in it.
Posted on Jan 09, 2009
  • 10 Answers
SOURCE: Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Posted on Jun 12, 2009
  • 749 Answers
SOURCE: My Panasonic 27
your tv set need parts Resoldering.
intermittent color changing is cause by cold solder joints.
have it serviced by a reliable electronic repair center or person.
you should not be charge a lot.
if you wish to fix it yourself,
you need a Soldering Iron (about 60watts) and soldering Lead (60/40).
air blower (for fast Cleaning) or
[1inch paint brush (for cleaning)]
unplug and place your set to your work bench then open the back cover.
(since you say its old, expect lots of dirt/dust inside your set, use the blower for easy cleaning).
if you have completely access of the solder side of the circuit, just resolder the joints. BE CAREFUL... DO NOT CONNECT SEPARATE JOINTS.
if you don't have experience with electronics i advise you have it to a repair person.
hope this helps you!
Posted on Jun 14, 2009
Hitachi 35CX30B 35" TV cable connection problem.
Check the cable connector, poor signal cause the blue screen
Or check the tuner if lose solder
Jan 09, 2014 | Hitachi 35CX30B 35" TV
LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
Intermittant picture interruption
When someone sees blue fast, it often appears as purple. Check the connections as it may be a loose wire.
Feb 16, 2009 | Sylvania LC420SS8 LCD TV
No Picture on screen
THIS PROBLEM HAS HAPPEN TO ME WHEN MY LAMP WAS
ABOUT TO DIE. WHAT I DID WAS UNPLUG THE TV SET FOR
A SHORT WHILE, THEN WHEN PLUGGED AGAIN IT CAME ON BUT THE PICTURE WAS DIM AND THE LAMP ONLY
LAST FOR FEW DAYS AFTERWARDS.
W.J.M.
Jun 23, 2008 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 57TWX20B Picture Problem
I just answered this please see my last post
Apr 23, 2008 | Hitachi 57F500 57" Rear Projection...
High definition reception
You should have 2 cables going into the Sky HD box not just 1
Oct 31, 2007 | Toshiba 52WM48 52 in. HDTV-Ready...
Toshiba 42wt29b. screen keeps turning blue
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
