Question about Kenmore 94223 Electric Kitchen Range
F1 Code on display
The oven was heated to 300 degrees, I noiticed that the broiler coil was the only one on and shortly after that an F1 code came on the display and 3 short beeps occured - I could not shut down so I turned off at the breaker - the door did not lock however it looked like it had been set in cleaning mode - what is going on?
  • risefromash2 Sep 30, 2008
    I have the same problem...F1 came up after the oven was on and the oven wouldn't shut off with out hitting the breaker. how do we fix this?
  • 4 Answers
The model # is incorrect...please post correct m #....
Posted on Aug 31, 2007
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
My oven shows an E7 on the control panel of my Maytag che9800bce
the tech sheet says " Function key shorted or stuck button" ,I suggest you to try to play around with the buttons and test the bake element for continuity
Mar 07, 2013 | Kitchen Ranges
I have a maytag range/oven model mgs5770adb and keep getting an F1 code on the display
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel -don't spray directly onto the surface of the touchpad.
3. If these tests all check good, then replace the ERC.
Sep 23, 2010 | Maytag Ovens
When the oven is on 350 for 15 min the broiler goes on I un plug it then pulg it in the F1 comes on
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
$%$rt
Sep 30, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door locks, the panel beeps, and displays F1 error code
gy^%$^
Jun 08, 2009 | Kenmore 92320 / 92321 / 92322 / 92324...
I have a Kenmore Elite 79075903990 gas range, got an f1 error replace my digital keypad. Then my oven wouldn't work just the broiler. I replaced my oven ignitor and it still won't get hot! Now what?
Jan 25, 2009 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Oven not heating
$%$^%rtd
Jan 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F1 Displayed and oven coils get super hot.
Nov 18, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
After preheating, the convection oven displayed F1 and did not heat further
^&^%tg
Jan 29, 2008 | Kenmore 64282 Convection/Microwave Oven
Kenmore 94223 Electric Kitchen Range Logo
255 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
