Question about Mitsubishi Televison & Video
Black drive belt
WHERE CAN I PURCHASE A MAIN DRIVE BELT FOR MITSUBISHI HS-U51
4 Suggested Answers
  • 1153 Answers
SOURCE: Replacement Belts for Mitsubishi HS-U560
You can try Vancebaldwin.com or MCM electronics corps, or even tritronics INC.
Posted on Mar 22, 2008
  • 44 Answers
SOURCE: I cannot remove a vhs tape from my Mitsubishi
If you are handy,
1) Unplug unit from power outlet before you do anything.
2) Take the top off /remove - screws usually phillips on both sides.
3) You will probably find the tape of the VHS wrapped around or pulled out of the cassette so you could cut the tape and probably pull the VHS out of the unit.
4) This deck sounds like it will need some cleaning and attention.
Might be a good idea to take it into a qualified TV repair shop and mabe for a small fee they can clean it.
Blessings,
A/V Media Tech Guy
Posted on Nov 25, 2009
  • 80 Answers
SOURCE: Mitsubishi U51 vcr cassette will not come out
THE BELT COULD OFF COME OFF THE PULLEY THAT IS WHY THE TAPE IS JAMMED
Posted on Apr 23, 2010
How do I make the cassette door close on a Mitsubishi HS-U550?
Usually on the older VCRs the problem is caused by a slipping belt. You would have to remove the cover and check to see if the belt is worn and can not turn the drive.
Oct 05, 2014 | Televison & Video
Error code in konica minolta c200 p 21
Relevant parts
Black PC drive main sensor (PS16)
Black PC drive sub sensor (PS18)
Main drive unit
Printer control board (PRCB)
Step Action
1 Perform the faulty sensor check procedure. *1
2 Check the sensor, for which a faulty condition has been checked, for installed position and
proper connector connection.
3 Wipe the sensor, for which a faulty condition has been checked, clean of dirt if any.
4 If P-12 persists, change the main drive unit.
5 Change PRCB.
Relevant parts
Transfer belt unit
PH unit
Step Action
1 Check the flat cable for proper connection and correct as necessary.
2 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
3 Change the image transfer belt unit if the transfer belt is damaged.
4 Change the PH unit.
5 Change PRCB.
Aug 21, 2014 | Office Equipment & Supplies
How to install need diagram of timing belt replacement
2003 Mitsubishi Lancer 2.0L MFI 4cyl
Fig. Accessory drive belt routing-1.8L, 2.0L (SOHC), and 2.4L (4G69) engines
Fig. Accessory drive belt routing-2.0L (DOHC) engine
Fig. Accessory V-belt routing-Mitsubishi 1.5L, 1.6L, 1.8L, 2.0L and 2.4L engines
Hope helps (remember to rate this ansswewr).
Jan 05, 2011 | 2003 Mitsubishi Lancer
Need two belts for mitsubishi HS-U59 vcr. Is there a source ?
Try Suburban Electronics---
www.suburban-elect.com
These belts are getting harder to find and some do offer kits with all the belts.
SD TECH Steve
Jun 10, 2010 | Mitsubishi Televison & Video
Apr 17, 2010 | Mitsubishi HS-U510 VHS VCR
Mitsubishi black diamond E4 fault
your VCR has a problem with the drive belt CAPSTAN, maybe is broken or fallen, you have to take it apart and check that the band is in order
Mar 16, 2010 | Mitsubishi HS-U445 VHS VCR
Mar 22, 2008 | Mitsubishi HS-U560 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
