Question about Sterling Stairlifts Stair lifts - Sterling 950 Straight Run
Won't move got power
Got. Electric but no green light look like all safety is OK
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
Aug 09, 2012 | Electric Mobility Merits Electric...
Ge dsxh43eaoww won't start or anything, light on when open door, i have 240v coming in what's else can i check ?
I would start with your door switch it will not operate with this bad. Remember to rate my solution and give testimonial it is how i earn my achievements Thanks in advance.
Apr 23, 2012 | GE DSXH43EAWW Electric Dryer
Nothing comes on, no power, no lights
check fuses if ok then see if voltage to unit if ok then check transformer if ok then check safety circuit if voltage to safety circuit then bad display
Jan 13, 2012 | Hayward CSPAXI11 11Killowatts Electric Spa...
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Blade wont move
there is a broken gear in the gear reduction box. (explain:) the motor spins at a high rpm, the chain moves at a 1/4 or less rpm than the motor. a series of gears reduces the speed, which in turn creates torque, allowing the saw to have the force to keep cutting without stopping. One of the gears is broken or a keyway on a shaft is sheared...as far as i know, no electrical power tools are rebuildable. it's a safety thing (electric shock if reassembled wrong...they are priced for replacement...get a new one...
Jun 06, 2010 | Black & Decker CCS818 Chain Saw
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Canon ip4300 service error b200 green and orange light keep flashing ink toner won`t move
Try this:
Pull the power cord out of the back of the printer.
Then move the printhead to the center and pull out the ink and the printhead. Clean the printhead and examine the bottom for burned areas.
With the printhead still out, close the cover and plug the power in and turn the power on. If your printer isn't damaged, it should go through all diagnostics and give you a solic green light. This means you probably need a new printhead.
Apr 17, 2009 | Office Equipment & Supplies
Electric power cord
good safety move to turn off gas
Apr 11, 2008 | Frigidaire FGB24S5A Gas Single Oven
Sterling Stairlifts Stair lifts - Sterling 950 Straight Run Logo
76 people viewed this question
Top Sterling Stairlifts Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a Sterling Stairlifts Heavy Machinery Expert? Answer questions, earn points and help others
