Proscan tv no picture 24" led PLED2435A-D
No picture - screen just turns different colors
  • 956 Answers
SOURCE: 47" Proscan LED TV Manual
What's your question, if missing, go on line type in specs of TV in a search engine and follow through. Happy surfing!
Posted on Dec 26, 2010
FSAhead2
  • 214 Answers
SOURCE: does the Proscan 47" LED
yes it does , if you are viewing the TV from the rear it is located in the back on the lower right , on the right side of the RCA's . here is a link to give you a visual , just wait for the manual to pop up .
http://www.managemylife.com/mmh/owner_manuals/15565/PROSCAN-LCD-Television-L1001098
Posted on Jan 28, 2011
  • 47 Answers
SOURCE: dynex 24" lcd led tv
Check to see if mute is on, and through the menu to see is sap is on. Sometimes button are accidentaly pressed. If none of the above, the ntry replaceing your main board.
Posted on May 05, 2011
Slinteriors
  • 8617 Answers
SOURCE: Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Posted on Mar 03, 2012
gopakumarg43
  • 75581 Answers
SOURCE: no picture just vertcal colored lines and sound
What is the exact model number to your Poloroid TV?
Posted on Jul 13, 2012
How much does picture tube for 42 inch flat screen Sanyo TV cost
There is no picture tube in a modern flat screen TV.
And unless it's physically broken, it's usually something else that has failed and not the screen.
A picture tube is a CRT (cathode ray tube) that sends electrons from the back to the front to light up different color phosphorous dots.
A modern flat screen TV on the other hand is LCD (liquid crystal display) that turns on and off to allow backlighting through multi colored filters. (LED TV also uses a LCD screen, the only difference is the backlighting is LED and not fluorescent lamps.)
Nov 26, 2016 | Sanyo Televison & Video
Have 24" Proscan tv bought 2/2016 picture starts out nice but within a few minutes is all pixels model: PLED 2435A-1
Open the cover buy a canister cold-spray and if you see the picture will begin mutate spray on the ( t-con ) board immeaditly it should give a point where it must me changed back into a good picture, IC most case SMD parts are defect or in this cause maybe also electrolytic capacitors or integrated resistor circuits.
I think support is there is support in your Country but i don't trust the way that its giving a security warning for my Country .
The brand is not accommodating to be help full . the link its working on a unlock email ?? becareful.
http://www.proscanvideo.com/manuals-downloads
Jul 06, 2016 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
Proscan 32" LED TV. Picture colors are opposite of correct, mostly reds and yellow. Any movement on screen shows multiple images. Refresh is slow or not working.
The TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 06, 2016 | Proscan Televison & Video
Proscan tv power light blinks red and won't turn on, it normally is solid red when off and turns blue when on. whats wrong?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Aug 28, 2014 | Proscan 42LA45H 42 in. LCD TV
What does it mean to do a auto search on 24 inch proscan PLED2435A-E having trouble setting it up
You have to connect the antenna, switch ON the TV and go to its menu; using its remote control, and do an auto search function. For more details, check its user manual.
Gopakumar Gopalan Google
Aug 13, 2014 | Televison & Video
Digital signal is blocked from TV
I really need a little more information to help with your problem. Do you have your TV connected to a satellite or cable receiver box via an HDMI cable or are you attempting to use the built-in digital tuner to receive HDMI over a HD antenna?
Aug 01, 2014 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
My Proscan led TV (PLDED3273A) is switching color from red, blue, green, white, and black.
hi first you will need the proper remote control once you have this press the menu button on the remote, retune the tv hope it helps
regards
shaun
Apr 01, 2014 | Proscan Televison & Video
Does sound bar connect to AV-IN?
This is an old post, but I will answer just in case the owner has never gotten his answer.
This model TV has a 1/8th inch headphone jack. You will need a converter cable that converts from 1/8th inch stereo to dual left and right RCA connectors. Get one of sufficient length to reach from your TV to the soundbar and you should be good to go.
Feb 23, 2014 | RCA PLED2435A - Proscan 24 LED 1080p 60hz...
When i turn proscan tv on it automatically turns off(just turn on for less than secon
OK I Have a 40" Proscan 40LD45Q
had the power problem when you turn it on it would flash and then cut off again.
after checking I found that the transistor on the power board was bad.
Its one of the 2N4401 transistors found on the cold side in between the
cluster of resistors and and mosfet heat sink. kind of hard to get too
but replaced it and tv works great now.. $1.19 at radio shack for the part.
Hope this Helps ..
By Lynn
Feb 22, 2012 | Proscan 40LD45Q TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
