Question about Refrigerators
Frigidaire Model frt221rsh
Fan makes noise on starting stops after a while.
3 Suggested Answers
  • 77 Answers
SOURCE: Evaporator fan stopped spinning
while you have pannel off replace heating element on the evap. this is causing the ice buid up.. after defrosting with hair dryer if you were useing a sharp object you cold of put a hole in the evap and lost all freon use hair dryer.. make sure you do not bend the fan blades if so you might have to replace, make sure same blade degree is replaced marked on blade most of time....
Posted on Aug 12, 2009
  • 2699 Answers
SOURCE: I moved my refrigerator to
the condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
Posted on Jun 23, 2011
Fan in nissan pixo 2009 making noises on number 1 any reason why please
The fan bushing are wearing out,, at low speed it just wobbles around, when you speed up, it "self-centers" and stops making noise... won't be long before it starts making noise on all speeds.. just prepare for replacement.
Jun 06, 2017 | Nissan Cars & Trucks
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Samsung model RS263TDBP/XAA
How to Test the Fridge Fan on Samsung Refrigerator Once you have the fan motor out put a drop of machine oil in the bearing caps. That will stop the noise.
Feb 14, 2018 | Refrigerators
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
The feezer side is making a loud noise and will not stop. it seems to still be cooling just fine on both sides. thier is no burning smell or anything. i tried dissconnecting the ice maker and that did...
From what you're describing it sounds like the freezer fan motor is causing the noise you hear. The freezer fan is the only moving part in the freezer section. I recommend replacing the freezer fan motor & fan blade together. If there is ice buildup on the back wall of the freezer then the sound is likely from the fan blade hitting the ice and you will need to defrost the unit.
Jul 31, 2011 | Frigidaire Refrigerators
I moved my refrigerator to vacum (Frigidaire model PLHT217TAK 2002) and since then the warm air stopped coming out from the front bottom vent. It also stopped making noise, it seems to want to start but...
Jun 23, 2011 | Frigidaire Refrigerators
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
Fan Blower Makes noise
Sounds like the fan needs to be replaced. But first, to check for obstructions, remove the carpet liner from the underside of the dash on the passenger side and you'll see the blower motor under the dash held in with three screws. If there's something obvious blocking it, remove it and reinstall the fan. If there's nothing blocking it, then you'll probably need to replace the fan. Any auto parts store, Rockauto.com or E-Bay will have the correct fan for your Grand Prix.
May 26, 2010 | 1998 Pontiac Grand Prix
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
