Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
I have a Kitchen AId dishwasher (8573025) and it is leaking about mid-cycle. I can't tell where (in terms of front, back, or side) the leak is originating. Any guesses?
This machine is about 5 years old, and I can't afford a professional right now. Sure would appreciate any tips. (It doesn't seem to be leaking during the final drain, but I can't be sure....) Thanks!
catriver
  • 878 Answers
SOURCE: Dishwasher
Tom, three things you want to check. 1. the heating element. Remove the leads from the element and ohm it out. Should read between 11 and 31 ohms. 2. Check the high limit thermostat. This sits right behind the drain pump on the right and inserts into the tub housing. Remove the leads and check for continuity. 3. The vent wax motor is inoperable. Check for continuity on the wax motor terminals. You can also put the dishwasher into a service mode to check the operation. In this sequence press high temp scub-energy saver dry-high temp scrub-energy saving dry. This will put it into a auto test mode. Let it do it's thing. If you need any further details, you can email me at catriver1@gmail.com Catriver..post back.
Posted on Mar 19, 2007
larryyb
  • 291 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
localwonder
  • 6784 Answers
SOURCE: Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Posted on Jun 21, 2009
  • 672 Answers
SOURCE: KitchenAid dishwasher allows water to drain while washing
Your dishwasher is siphoning the water out. The drain hose should turn upward, nearly to the bottom side of the counter top, before it attaches to the drain or disposal. If it has an independant drain it still needs the rise and also needs an air break to stop the siphoning.
Posted on Jul 18, 2009
Kitchen aid dishwasher stopped mid-cycle and won't drain. Can't re-start. Suspect clogged drain.
This blog might help: http://www.applianceblog.com/mainforums/threads/24574-Dishwasher-stopped-mid-cycle
Mar 10, 2015 | KitchenAid KUDE70FXSS Builtin Dishwasher
Machine jams after 4 or 5 stitches. Bobbin thread locks up.
try these suggestions
change the needle
make sure the thread doesn't come off the thread take up lever--this
can jam the machine
make sure the bobbin is turned the right way in the bobbin case--this
can cause problems if the bobbin is turned the wrong way
make sure the bobbin is not warped or damaged
make sure there are no burrs in the bobbin area or on the needle
plate
Oct 16, 2012 | Singer 8280 Mechanical Sewing Machine
Kitchen aid 8573025 B and the light panel blinks but will not operate
if the light is flashing 7 times there's a heat problem and the dishwasher won't start,if you remove the bottom kick panel you'll see the tech sheet,it will tell you about the flashing error codes, count how many times it flashes and look up the code,if it is 7 times you either have a bad heater or computer board,if you look at diagram it will show you how to read out the heater from board to see if the heater is bad or it's the board.
Jul 29, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
New Home ss2015 machine. I am having trouble with the thread tension. I have loops on the bottom. I have cleaned the bobbin case, changed the needle, re-threaded and moved the upper tension all the way up....
try adjusting the top tension to 3 & if it doesn't stop the looping, try 4 but I wouldn't go any higher than 5,, if changing the top tension doesn't help then I suggest taking the machine in to have it serviced. the bottom tension is more difficult to do,, it's also very possible that the top tension dial is messed up & needs replacing. only a sewing machine shop can tell for sure.
Mar 02, 2012 | Sewing Machines
I have an older model (bought it about 15 years ago) top loading Kenmore washer. I noticed that the spindle that is part of the agitator doesn't move as much as it is supposed to. In fact, if you...
That sounds as if the parts called the agitator dogs are worn out and thats a pretty easy thing to replace the dogs and fairly inexpensive (the parts are less that $8.00) this tip i wrote explains how to replace the agaitator dogs. http://www1.fixya.com/support/r10294924-top_part_agatator_isnt_turning_top_load
GENE
Sep 18, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My Keurig B40 has been working fine, no problems ( my husband thinks it's two years old). Last night, it was plugged in,however, no lights on, and doesn't work at all! Any suggestions? Or is it...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
Video worked fine till the power black out last week. The machine was off when the power came back on. I tried a different monitor that I know works, I re-seated the ram, and bought a new video card but...
hello
You should try first the onboard VGA output of your motherboard to be sure if the Video Card is damaged. And to be sure f your motherboard is working. Keep on touch
Aug 28, 2011 | Computers & Internet
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
67 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
