Question about Digital Innovations 4310100 ChatCam Webcam
Driver download CD-ROM Disk - Digital Innovations 4310100 ChatCam Webcam
Drivers for cd rom model lg GP30NB20
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Oct 26, 2012 | LG CRN 8245B (CRN-8245B) Internal 24x...
Hi having problems with my partners Fujitsu Siemens ScaleOP Desktop Computer. She recently reformatted the PC with a Genuine copy of Windows XP which installed perfectly without any hitches but when...
Can the drive read other disks? I'm guessing no. If no, it would appear as if the drivers for the CD rom are not loaded. If this is the case, you will need an internet connection to download the drivers for the cd rom so it will work. Other than that,you can try to install generic cd rom drivers through windows, that may work. Good luck.
Sep 26, 2012 | Computers & Internet
I need an install driver
hope this helps you
Feb 03, 2012 | Micro Solutions Backpack (164550) External...
DRIVERS LG CRD 8522B Internal 52x CD-ROM Drive
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down
cd dvd rom drives if you see a yellow question or exclamation mark? ! or a red X right click to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
Adaptec
Oct 13, 2011 | LG CRD 8522B Internal 52x CD-ROM Drive
CAN YOU HELP ME TO FIX MY PC TO UPDATES MY DVD DRIVERS
click start control panel administrative tools computer management device manager scroll down cd dvd rom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Oct 03, 2011 | Lite On LiteOn LH-20A1P - Disk drive -...
Latest firmware?? Where download?
http://www.eid.toshiba.com/support/swdrivers.shtml
If the boot disk came with your laptop, it should have the necessary drivers on it. You cannot burn drivers on your CD-Rom boot disk because it is not made of the material suitable for laser burning. Even if it were, it would have been "finalized" and the CD writer would not burn it.
First of all, you have to enter the BIOS Setup to see if the drive is detected. If not, then you have a hardware problem, loose connection or bad drive.
Boot to your C: drive and go to the Toshiba link (above) to download the drivers. Then install the CD-ROM via Control Panel>Add Hardware route.
hope this helps
May 15, 2011 | Toshiba XM 1802D (XM1802D) Plug-In Module...
When inserting a disk, the CD ROM spins but does not read the disk nor does it show up in "My Computer". Under Device Manager, it shows up with an exclamation mark. I've uninstalled and re-installed it to...
Please try running the Microsoft Fix It from the link below. It should resolve the issue for you.
http://support.microsoft.com/gp/cd_dvd_drive_problems
Robert from Blitware
Jul 08, 2010 | Dell Inspiron 5100 System Board (...
Canoscan Setup Utility CD-ROM missing
You can find drivers here. Select your OS in the box, then download the standard driver (not the WIA driver). Also download the CanoScan Toolbox listed under Software. Install both to your computer following the instructions.
Jun 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Digital Innovations 4310100 ChatCam Webcam Logo
42 people viewed this question
Top Digital Innovations Computers & Internet Experts
David Payne
David Payne
Are you a Digital Innovations Computer and Internet Expert? Answer questions, earn points and help others
