Question about Dryers
Emerson blower motors k55hxjms-9215
Over-amping on 120 volt circuit
SOURCE: 2004 Dodge Dakota
Replace your resistor if you haven't already. I had the same issue with mine, it only worked on high.
Posted on Dec 30, 2008
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
erpaalai
  • 999 Answers
SOURCE: i need to rewire a 239 volt motor to 120 volts.
There should be a wire diagram on the motor tag or under the coverplate. Eric
Posted on Aug 11, 2009
  • 7 Answers
SOURCE: Heater Blower Motor not working.
I don`t know what year your car is but my 91 Escort had 4 little connections under the glove box where the passengers feet would be right in front of the blower moter (i.e. some one sitting in the passenger seat could hit these 4 relay type things if they kicked their leg) and my had been dammaged and that stopped my blower motor from working until I straightened them out and reconnected them all.
Posted on Mar 10, 2010
palaboy
  • 5807 Answers
SOURCE: Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Posted on Sep 09, 2012
My roper dryer had a 4 prong cord. i changed it over to 3 prong. now it will not start
Your dryer requires 120 for motor operation. It only needs 240 volts for heater operation. Since the motor is 120 volts it is on a different circuit than that of the heat. On your terminal block is a white wire in the middle, that is neutral and it is needed to drive the motor. On either side is a black wire and a red wire. The motor runs on the white and black circuit. The heater circuit runs on red and black.
The motor circuit has a fuse in it mounted on the blower wheel next to the control klixon. If it is open the motor will not operate just as the door was open, door switch is also on the motor circuit. The motor has to be operating for the heat to come on also because the heater wires go through the motors centrifugal switch.
Dec 31, 2012 | Roper Dryers
Does adding more electrical outlets require to increase breaker amps/condiut?
Yes maybe, depending on what you are doing.
1) Electric Code generally says Maximum 12 boxes per electric circuit controlled by 1 circuit breaker. If you have more boxes, then your house can fail inspection IF inspector finds problem. But it is a minor problem if wire size, breaker size, and amp loads are safely matched.
http://waterheatertimer.org/How-to-wire-switches.html#add
2) Reason for the code: so there is not power loss to last box when many things are drawing power from same circuit, which can cause overheating of circuit and trip breaker, and cause heat damage to some electronic devices and motors.
Which is why you are asking the question.
3) In practical terms, if you are adding outlets to run another light bulb, then you will probably not notice any problem.
However if you are adding plugs so you can run shop tools, or blower motor, or compressor etc, then that can be a problem.
For example if wire is too long, there will be power loss to motor which will cause motor overheating and shorten life of equipment.
4) Solution.
Calculate total amps and watts expected on that circuit.
Add up watts of everything running at same time.
Volts x amps = watts
120 volt microwave uses 1500 watts, how many amps?
Amps = watts divided by volts, so 1500 watts divided by 120 volts = 12.5 amps.
Compare your total expected amp usage to charts on following link.
Make sure you have correct wire and circuit breaker for expected amps. Oversizing wire and breaker are good idea.
http://waterheatertimer.org/Color-codewire.html
Oct 27, 2012 | Electrical Supplies
Can I use my Intermatic model T-103 switch for 2 separate 20amp 120v circuits?
Yes, the timer motor is 120 volt, so connect both neutrals from each separate 120 volt circuit to the "A" terminal. Probably best to place all the neutrals (line and load) under a wirenut with a jumper going to the "A" terminal. The terminals are intended for only two wires.
One hot will go to terminal #1 and the other will go to terminal #3. The 120 volt timer motor is connected internally at the factory to the "A" terminal and terminal #1.
Dec 07, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
What is the wattage?
Hi .. Wattage is a measure of power .. it is the voltage a device opperates at multiplied by the amount of amperage it uses. Sometimes called volt- amps. For an example of this, a 200 watt lamp, on a 120 volt circuit, is using about 1.66 amps. That typical circuit is rated for 15 or 20 amps. The rating is determined by the wire size and the breaker protecting the circuit .. so on my lighting circuit I can install about 8 to 10 of these lights and be safely within the limits of the circuit. For a 1000 watt microwave , on a 20 amp kitchen circuit, this means that the microwave is using about half of the capacity of the circuit. You are charged for your use of electricity by a rate times your usage in kilowatt hours, or how many watts you use, times the hours you are using them.
May 06, 2010 | Emerson MW8985W Microwave Oven
120V INSIDE UNIT BLOWER INOP DIAG TEST FOR A TRAIN TDE100A945KD (GAS & A/C)AND CONTROL BOARD EMERSON WHITE-RODGERS 50A50-571
If the blower motor is indeed 120volts, and you don't have a meter to see if you are getting power to it from the board, if you are handy, pull out the motor and apply 120 volts to the same leads that go to the board, carefully! If it runs, more then likely, the blower board is faulty. Let me know, and we can go further into it if not.
Sincerely,
Shastalaker7
Apr 16, 2010 | Heating & Cooling
System ignites blower won't kick on
if its an older furnace, check the fan switch n that the blower motor has 120 volts. if its newer its prob the circuit board. check if the fan comes on switching the thermostat fan switch to on telling u if the fan motor works. good luck
Nov 23, 2009 | Heating & Cooling
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
My blower motor will not stop running,and my ignitor doesn't light.
I am assuming you are talking about a Natural Gas or LP furnace. The blower motor is powered by a separate 120 volt circuit, so flipping the 240 volt breaker for the furnace will not shut it off. There should be a regular light switch at the furnace that will turn off the blower for servicing the unit. When you take the cover off the unit, there should be instructions on how to re-set the igniter. If it won't re-set, try shutting off the gas for a few minutes, then turn it back on and then reset. If none of this works, and you can't find the owners manual, call a service technician.
Feb 22, 2009 | Electric Circuit Breaker Kit for Furnace
Dryers Logo
47 people viewed this question
Top Dryers Experts
