Sudden shutdown My laptop suddenly shuts down after a couple of minutes. The fans turn on at the beginning but then never again during the computers on period. The heatsink gets real hot and the cpu usage stays over 50% most of the time. I cleaned and added thermal grease and the same problem occurs.
  • mikey8 Aug 27, 2007
    The computer just turns off, and at time the ac adapter light doesnt show after it turns off. I changed the fans and still nothing, and how do I check the temperature?
  • Anonymous Feb 28, 2009
    my computer sometimes is over temperature
    Problem Solver:
  • 17 Answers
What you have not indicated is whether it shuts down or restarts. If the laptop restarts then it is possible that the processor is a celeron and there is a problem of a overheating. If you are sure about all software issues be alright, I suppose you get a new fan. At times after a fan has gone weak, regardless of the contacts it has with the processor, it will still not cool; but it also be good to check the processor temperature if its goes over 60 degrees. good luck.
Posted on Aug 27, 2007
Server Randomly Reboots
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP
Mar 04, 2013 | Dell PowerEdge T300 Server
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
Thinkpad A22m 2628-3SU laptop premature shutdown
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
May 18, 2012 | IBM ThinkPad A22m 2628 Notebook
My sony viao vgn-cs215j suddenly turn off by itself and it takes 20 minutes before i can re-start and use it again and after 15-20 minutes would shut off by itself again without any warning. what could be...
Sorry i nay be a month late on this thread... but better late than never. My Girlfriends sony vaio VGN-CS215J seems to be doing the exact same thing. After buying one of those computer fans that you rest the computer oneverything seems to be running normal. i would also recommend cleaning your fans inside the computer because dirt dust and grime can hold the fans back from cooling down the laptop efficiently and will cause the safety overheat shutdown to activate and shutdown your computer... that way it does catch on fire or fry any of your hardware inside of your computer.
If that does not work... your fans maybe malfunctioning or not functioning at all. this model of vaio has a grinding fan issue that can be very damaging to your cpu if not fixed.
hope this helps,
Mike Huffstutler
Apr 06, 2010 | Sony VAIO VGN-CS215J/W Notebook
About 10 seconds after i turn on my aspire 3690 the fan shuts down. the laptop will run for several minutes and then it shuts down also probibly from overheating. The fan starts each time i start but shuts...
First thing I'd check is for a BIOS update for your computer under the Acer support pages ( In some cases, thermal control updates are included in newer version of the BIOS, if it is a manufacturing problem.
Goto and download Hardware Monitor, start the computer and immediately run the hardware monitor app to check how high the temperature on the CPU gets before it shuts down.
Continuing use under this condition may damage your Windows installation because of the sudden shutdown.
Mar 21, 2010 | Acer Aspire 3690-2196 Notebook
Sudden shut down
You need to clean it out with some compressed air.
Make sure the laptop is turned off of course.
If you still have heating issues, then you'll need to take it apart and put a new layer of thermal paste on the heat sink / cpu.
Best of luck!
Jun 18, 2009 | Computers & Internet
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
Dec 19, 2008 | Apple Power Mac G5 Desktop
Sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
Dec 16, 2008 | Dell Inspiron 6000 Notebook
Overheating and sporadic shutdown - does this follow screen freezes and fan stopping?
I would suggest you have the fans/heat sinks cleaned as soon as you can. it is most likely shutting down because of heat (thermal shutdown). on some laptops the fan doesn't come on till close to melt down (my inspiron laptop is great for that). If you are at uncomfortable with taking the bottom of the laptop off to clean out the dust and dirt from the fan take it to a shop and have it done.
you may want to invest in one of those laptop chillers... basically a stand with fans on it. they make usb ones that get there power from the usb connection. abit ruff on the battery if you are not using a/c but better then replacing the cpu.
Please rate my solution thanks
Aug 31, 2008 | Acer Aspire L100 PC Desktop
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
1,177 people viewed this question
David Payne
David Payne
