Question about Epson Stylus CX5400 All-In-One InkJet Printer
Epson CX5400 Printer Error Light and Message
My all-in-one scanner printer won't print, even offline. When trying to do a nozzle check, for instance, it loads a few sheets of paper, moves the head across and back a few times, pauses, then goes into error with the red light on, and a message "Printer problem >>> Check documentation or call for service". It scans fine to a file (won't copy to printer), and this just happened after it was working fine, except for faded copies cause the printer had sat too long. I'd recently changed to some after market cartridges, then a piece of paper got jammed into it, which I removed, and I've disassembled the unit and verified that there is no debris whatsoever in it. I also cleaned out the excess ink and head. I've also gone as far as I can go with Epson Tech support, who just want me to return it for service (out of warranty). One other note, sometimes when it loads paper it makes chattering sounds that I believe are coming from the lower gear/cam on the right side. Regards, Bill [email protected]
  • 1 more comment
  • Bill Kurinko Aug 31, 2007
    Thanks for the support. As it turned out, I downloaded the Epson CX5400 manual from 2manuals.com, and the remedies for the printer error light were plain and fell into 5 categories; print or carriage motor ohms out of spec (not likely), a latch holding the paper eject mechanism not locked down, or one of the sensors for head or paper position not functioning properly. Confident with this new information, I aerodusted both sensors, cleaned a smudge off the CR alignment strip behind the head carriage, and also reseated the head for good luck, as I'd had it out before. I ran a test and YEA VERILY it worked! Now to get the terrible ink feed to improve after numerous head cleanings and a few cartridge changes and I'm back in business.
    Bill
  • Bill Kurinko Sep 01, 2007
    Jackboy, that is sheer genius! I'll try it today but probably won't have the results for a few days. I was going to yank the head assembly out and soak it in an ultrasonic bath of alcohol, but this "fuel injector cleaner" solution allows you to test the results easily. I thought those spikes that pierce the cartridge were fibrous wick types, but I have some small plastic tubing that'll fit them nicely. I know this head assembly is so plugged up I've almost complete wasted a new set of cartridges using the head clean and cartridge charging features of the printer to no avail.
  • Anonymous Mar 13, 2014
    i had a epson multifunction printer (print/scan/copy), epson tx 111.
    now, everytime i turned on the unit, it always make a grinding sound on the scanner side, opened the unit, turned on again, and looks like the scanner head (?) stuck on the end side, but the motor still running. already tried to move the scanner head to the other end side, but still the same, the head will move to the other side (right side) and then the motor will run for about 1 or 2 minutes with grinding sound (stuck), after that the unit's light on the paper & ink is on (red).
    any solution?
  • 1,218 Answers
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Posted on Oct 04, 2010
    Genius:
  • 2,985 Answers
Dont know how it is in the good old US but here in UK - Epson have this super 'swap out' scheme for the more complex devices that die out of warranty. What we do - is to phone Epson and tell them the tale. they will then offer to send FedEx with a new printer and you give the driver your old one all for a quick flash of your plastic friend. If they do it - go for it.
Posted on Aug 27, 2007
  • Anonymous Aug 31, 2007
    Well now I have just the tool the cleans heads by magic.- I was given a RX420 that had sat for a year and not going to print anything.
    But- my magic tool -wot I made myself- did the trick
    Here is a picture of it and detail-the Fluid is Alcohol based window/windscreen cleaner.
    Attach the device to the ink feed spigot in the base of the chamber and pump away until you get clear fluid back.
    On this one I had to leave the device connected under pressure overnight per colour[4 nights]
    but it came true.
    The tube can be anything that suits -a drinking straw/ feed tube from a disposable pump spray etc.,
SOURCE:
My epson cx5500 does not print (test print ) I've been through a nozzle check and have fresh cartridges.... just end up with a blank page
If the inkjet printer has not been used for some time, and the ink cartridges are full then the print head nozzles may be blocked. If running the maintenance nozzle cleaning does not clear the print head nozzles then the print head will need to be replaced.
NOTE - inkjet print heads are not cheap, it may be better to purchase a new inkjet printer.
Jan 17, 2011 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 will not print. This printer was unused and stored for 3 years. We replaced the ink cartridges and cleaned the print head and aligned the print head and ran a nozzle check. The printer...
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!You might have dried it up.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 11, 2010 | Epson Stylus CX5400 All-In-One InkJet...
My CX5400 printer just gave me an error message that says call service. It printed earlier today...
Might be time for you to purchase another printer.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
Good Luck.
Apr 05, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400
Please help....My scanner only shows a large corner portion of the copy. The menu reads ERROR
...no color CYAN etc etc I have contacted many technitions....None have helped The last person Claimed it had to do with low ink....It doesn't make scence. Isn't the scanner separate from the printing components?The printer is in excellant condition...but I was told to dump it and get another I do hope you can HELP....I am 83 yrs young and I have a budget problem....Many Thanks Phyllis
Jul 27, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400. I have 2 and both are giving 'error'red light and message 'scanner error' see documentation and caqll service if necessary'. I have rung an Epson Service centre and they say it is not...
Please follow the steps below to resolve your issue.
1. Turn off the printer.
2. Lift the scanner cover.
3. Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4. Turn on the printer, and the error should be cleared.
Update me if you are still getting the error message.
Apr 28, 2008 | Office Equipment & Supplies
Error red light on.
are you having an error on the LCD screen?
Mar 21, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
858 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
