Question about Cameras
Innotek adv1000p. How do I take the box apart to replace the metal and rubber parts?
4 Suggested Answers
  • 16 Answers
SOURCE: I have an old commercial
plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
jsrock516
  • 5911 Answers
SOURCE: The rubber seal on my washer came apart along with
The following link explains step-by-step how to install a door bellow on a Whirlpool Duet. I'm enclosing entire replacment steps just in case you need to replace the bellow. They can rip or tear when they become dislodged. Make sure you inspect the entire bellow for holes, rips, or tears:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Read through the link provided and let me know if you have any questions.
NOTE: There is another method you may try as well. Although I do not prefer this next method because these washing machines are very heavy, an alternative way of replacing the door bellow is to remove the lower toe panel and tilt the washer back at a 45 degree angle instead of removing the washer front panel. If you use this method, make sure it rests against the wall and will not tip forward. This allows the wash tub to drop down and away from the front panel and gives you access to the the rear bellow clamp through the bottom. This can save you some time. Thanks to user DGBG for the helpful tip!
If you would like some helpful exploded view diagrams of your washer that you can reference, you can use any of these web sites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
Just use your model number to begin your search criteria.
If you have any questions, please let me know. I hope this helps you.
NOTE: These door seals do wear out and require replacement from time to time. However, overloading the washer to the point where items get caught in the door area can contribute to premature wear and tear.
Posted on Oct 29, 2009
  • 2002 Answers
SOURCE: How do I remove a wiper blade from my 1983
Flip the arm up off the windshield first. Then use a screwdriver or small pry bar and pry up on the edge of the wiper arm. Alternate between sides and make sure you only have the edge of the wiper arm itself. You should be able to feel when you are on the edge and not on the drive nut. Be patient because the drive nut is white metal and can break. This should do it.
It is possible that there may be a small tab on the side of the arm if it has beeen replaced before. If you see that tab then use a screwdriver and open it first. It will only move about 1/16 of an inch or so but it is a lock and must be opened before you pry the arm off. Hope this helps.
Posted on Dec 05, 2009
Testimonial: "THank you for your help!"
How do I know which type LED diode my LG smart LED TV 50LB6300 uses on the backlight strips. Some are faulty.Need to replace. On the power boards it is written LOW 113V - 215mA and High 170V-215 mA
Unless you can either find the engineer who designed the TV or find someone who has already figured this out by trial and error, you are on your own to find an answer to this. I work on copiers, back in the 90's they included a pretty detailed schematic with the service manual which allowed you to figure out what other part to replace when transistor Q7 on board X burned up. That is no longer in the manual and even the people on the factory tech assistance hotline have no idea what part on the boards controls the other parts in the machine. Quite annoying at times!
Sep 11, 2017 | LG Televison & Video
Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Jul 01, 2012 | Innotek Pets - Others
The VAC switch is probably no more good on my minimax pool heater. I have a new one but can't find where it is located. Any suggestions?
The air switch is located inside the front heater cabinet on the right hand side. You must remove both sheet metal boxes on the right to access this part. Just follow the rubber tube into the lower metal box.
NOTE: on these units, its much more common to see the rubber tubing fail. Not the actual air switch. To check the tubing, remove from the air switch, then remove the upper right panel to access the fan area. Follow the tubing into the fan casing and and remove. Check to make sure rubber is not brittle, crackes, or broken. Replace if necessary.
Sep 14, 2011 | Pentair Minimax NT Heater
I have the 8" version. Does it come apart? I
the 8 inch version has 1 cartridge for hot and one for cold..shut off water.remove handle...unscrew metal retainers...these hold in cartridges....they ride in notches in metal...put in as you pull out 1 by 1..under these you should have 1 spring and 1 rubber seat replace those also if needed...sometimes easier if you do seats and springs if you have drips...cartridges rarely leak...good luck
Feb 20, 2011 | Danze & 4" Round Sunflower Showerhead -...
I need a manual for trouble shooting my Innotek Model 024101 electronic dog fence.
Innotek has manuals free for the download on their site. Your model number should actually be SD-2100 - the part number 24101 is for the transmitter only. That said, this should be the correct manual. If not, call Innotek at 1-800-826-5527.
http://www.innotek.net/Innotek/files/91/91bd9b70-6d16-4122-8ebb-86db65d904aa.pdf
Jan 28, 2011 | Computers & Internet
Plastic "Turbo Frother steam nozzle" blows off metal steam pipe
Pull off entire plastic wand off by unscrewing the top plastic piece. Inside the piece that connects to the screw top you should see two o-ring type spacers. The top one should be hard pastic and the one beneath should be rubber. Take the entire unit apart and clean, making sure to put all pieces back in the way they came out.
To put back on, take the top piece and put it back on the metal stem first then put the rest of the wand back on and gently push it as far up the metal stem as possible and screw back together. If you don't have the rubber spacer this could be the problem since the wand really has nothing grabbing onto the metal stem except for the rubber spacer. If this doesn't work, order another wand:
http://www.wholelattelove.com/Gaggia/gaggia_pannarello.cfm
Feb 27, 2009 | Gaggia Carezza Espresso Machine
Shocks or struts for front driver & passanger
The front has struts and the rear has shocks. I used Volvo OEMs. The rears are VERY easy to do yourself. The upper mounts are located behind the rear doors in the trunk area. It takes 15 minutes each to replace the rears.
The fronts are not difficult to remove if you have an air wrench + 6 sided socket, and a special star socket (14mm I think). You can find detailed instructions online. Once the front struts are out of the vehicle, you'll need to compress the springs before taking them apart. I did one myself using loaner spring compressors from Advanced Auto. I brought the second one into my local muffler shop because they have an industrial spring compressor. Make sure that you have a ride available to the nearest Volvo Parts dealer because once you get the struts apart, you'll probably need to replace the rubber bearing assembly in the strut that rotates when the wheel turns. There is also a rubber sleve that surrounds the strut to keep dirt out. The metal mount for his corrodes. The struts are a very important part of your steering, so if you do the fronts use care. Also, be aware that you'll probably be purchasing alot more parts than just the piston for the fronts. Suggest that you price it all out before proceeding.
Jul 30, 2008 | 2000 Volvo S80
Lost manual
Go to Innotek website and check out manual.
See site below:
http://www.innotek.net/documents/RR_300Smanual.pdf
Apr 05, 2008 | Audio Players & Recorders
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
