Question about Buffalo Technology Computers & Internet
Error 0x80070091 impossible to delete a file folder
2 Suggested Answers
  • 10406 Answers
SOURCE: My Music folder suddenly deleted all the files in
You probably have a disk-drive with some "bad" sectors.
So, when you try to read the sectors that contain the directory for the 'My Music' folder,
that sector cannot be read, and thus Windows reports an "empty" folder.
It's probable that your disk-drive is about to _completely_ fail, not just _partially_.
Make a backup of what files & folders that _can_ be read.
Posted on Dec 11, 2010
My Music folder suddenly deleted all the files in it, but the folder won't delete because it says it's not empty; however, it won't let me open it either. It keeps popping up an Error code 0x80070091: The...
Dec 11, 2010 | Western Digital WD Passport 250GB Portable...
Maxtor 1TB external HDD says files are corrupt
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 02, 2010 | Maxtor Hard Drive
Weird folder/filenames that will not delete There is a folder on my WD 250 GB Passport Flash drive who's properties show it to be using 157 GB of memory. The Read Only attribute was set, unchecked it. I...
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
Nov 25, 2009 | Western Digital Passport 320GB External...
File deletion problem from Garmin c550
If your undelete program lets you undelete the _P3 folder, do it. Then try renaming it to MP3. See if this helps. This is the folder in which all of your music is stored. If it allows you to change the folder name, you should now see (and be able to delete) all of your music files stored on the GPS.
Sep 24, 2009 | Garmin StreetPilot c550 GPS Receiver
Error 8E5E05F6: You can't sign in to Windows Live Messenger
Hi, If you are receiving Error 8e5e05f6 when you sign into Windows Live Messenger 2009, please try the following:
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
Sep 19, 2009 | Microsoft Windows Live Messanger
How do I fix Error 8E5E05F6
Try the following:
1. A. Windows XP :
Windows XP:
Windows Vista:
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Error 0x80070091 the directory is not empty
There is most likely a hidden or read only file located in this dir. Have you tried to view the hidden files?
Jun 11, 2009 | Microsoft Windows Vista Home Premium for...
I got one folder in games when i tried to delete it it give me this message...(error 0x80070091 the directory is not empty) i tried many ways already how to solve the problem but i have not succeeded.
do one thing if you got alinux (ubuntu) disc with you run it be carefull restart the computer
safely dont be in rush
then select the option run ubuntu without any change to your system then open the folder which is having the problem copy the items in it if u need it and the folder
or the best solution is delet the folder
AVG Free install fails
Install AVG8.0, it should fix your problem
Feb 10, 2009 | HP Pavilion dv6000z Notebook
Impossible to install downloaded applications
unzip this file using winzip / winrar software....once one of these software is installed in ur pc , u need to right click on this .jar file and select the "extract here" option.this wil unzip the .jar application & would provide u with a set up file or  .sis file....install this file in ur phone   & the application wil be ready to use.
Sep 25, 2007 | LG Shine KE970 Cellular Phone
Computers & Internet Logo
29 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
