Question about Dryers
Hayley 52" ceiling fan u52mk5wh4
How do you get the glass cover off to change the light bulb? It is not obvious...
Crossedwires
  • 44 Answers
SOURCE: How to Change light bulb (yes, really...)
If yours is the same as the model 04890 that I looked up on the net, you will unscrew the center nut of the light fixture being carefull to not let the fixture drop to the floor. Once you have the center piece off you will be able to unscrew the bulbs and install new ones. Be carefull and be sure power is off before you do this.
Posted on Feb 09, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
landsend
  • 1066 Answers
SOURCE: Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Posted on Mar 31, 2009
protek480
  • 1723 Answers
SOURCE: I am having trouble removing the glass cover on my
Try pulling down on it. There are some clips that will release it. It's not screwed on.
Posted on Jul 04, 2009
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
How to change bulb in northwind ceiling fan
THIS FAN HAS AN ADD-ON LIGHT. Your glass will be held on by thumbscrews or you have to twist it off,usually right to left.
Mar 09, 2013 | Emerson CF705 52'' Northwind Ceiling Fan
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
How do i remove the light to change a light bulb?
i looked it up online and they called it a:
Single Bowl Twist and Lock Light Kit.
Some things i would suggest:
  1. push it up and turn (like when you open a medicine bottle.
  2. try to look for a spring action peg that clicks in automatically around the glass dome that might be locking it...
please comment my solution :) thanks
May 31, 2009 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Light bulb burned out in ceiling fan
THE FAN IS ACTUALLY A WINWARD II BY HAMPTON BAY. ACCORDING TO INSTRUCTION MANUAL YOU TURN THE GLASS BOWL COVERING THE LIGHT ASSEMBLY UNTIL IT MAKES CONTACT WITH A COUPLE OF GROOVES IN THE RIM AND THE GLASS ASSEMBLY SHOULD RELEASE. I DID NOT RECEIVE ANY HELP FROM "FIXYA" BUT MAYBE THIS INFO WILL HELP SOMEONE ELSE WITH THE SAME PROBLEM. THE MODEL # OF THE HAMPTON BAY FAN WAS 523 342. (I FOUND MY INSTRUCTION MANUAL AND THIS IS WHERE I GOT MY INFO)
Mar 27, 2009 | Hampton Bay 24002 Ceiling Fan
How do I change the bulbs for this fan?
twist the glass on the bottom counter clockwise
Jan 11, 2009 | Hampton Bay 24002 Ceiling Fan
Ceilng Fan light fixture-metal clasps have broken off
For Hampton Bay ceiling fan replacement parts!!!
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
159 people viewed this question
Top Dryers Experts
