Question about Jenn-Air JCD2389G Side by Side Refrigerator
Jcd2289ae just need the dimensions (cubic feet)
How do I figure out or find how many cubic ft. Are in a 1999 kenmore refrigerator model# 70282990 ser. # EJ404016?
open the door
measure across the opening record it as a W dimension
now measure from the front to the back of the compartment
record that as a D dimension
now measure the height of the opening
record that as a H dimension
now the formula to determine cubic capacity is to multiply-- W X D X H
so put in your dimensions in feet and the answer is in cubic feet
Apr 29, 2018 | Kenmore Refrigerators
6000 cubic feet equals how many sq. feet
You can't convert cubic feet to square feet because cubic feet has an extra dimension, you could fit an unlimited number of square feet into cubic feet.
The formula for Cubic feet is:
length × width × height
The formula for Square feet is:
length × width
Aug 19, 2016 | Office Equipment & Supplies
How many cubic feet is 312 sq. ft.
There is no relation between square anything to cubic anything.
If you want to calculate how many cubic feet 312 sq tiles are, you need to tell how this the tiles are.
Cubic is length x width x hight.
square is length x width.
All in the same dimension so even 1/4 of an inch, should be added in feet. with 0,00xx I don't want to calculate in these old measures anymore.
Mar 18, 2015 | Measuring Tools & Sensors
How many cubic feet is a Frigidaire frt21tng 0
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The cubic feet is in your model number. In your case it is a nominal 21 cubic feet. It can be 21.2 cubic feet.
Sep 04, 2014 | Frigidaire Refrigerators
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
What is the cu ft of Model FRT21IL4FW3 Freezer space?
Easiest solution is to measure the inside dimensions in inches, tall, width and depth. Then multiply the three dimensions t x w x d = cubic inches. To get cubic feet then divide the above answer by 1728 and the result is cubic feet..
For instance if the fridge is 60 inches tall x 24 inches wide x 18 inches deep; the answer is 60 x 24 x 18 = 25,929 cubic inches... 25,920 divided by 1728 = 15 cubic feet.
Jul 12, 2014 | GE GSH25JSTSS Stainless Steel Side by Side...
How many cubic feet?
The cubic feet of a KSCS25FKSS is 25 cu. ft. Thanks Sea Breeze Click Here=> Dimension Guides KSCS25FKSS00.pdf
User Manual=> KSCS25FKSS00.pdf
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download
Aug 27, 2012 | KitchenAid KSCS25FKSS Side by Side...
I need to know the cubic feet of my upright frost free frigidare freezer Model # MFU17F36W6
get a measureing tape measure inside dimensions multiply them together eg: a freezer with an inside dimension of 2' X 2' X 3' would equal 12 cubic feet if want an exact value measure in inches 24" X 24" X 36" = 20736 and divide by 1728 will give you cubic feet cool eh.. where did I get the 1728? (12 X 12 X 12) =1728 converts cubic inches to cubic feet Good Luck let me know when you pour that cement pad for under your shed I tell you how many yards to order
Oct 23, 2009 | Freezers
Jenn-Air JCD2389G Side by Side Refrigerator Logo
109 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
