Question about Refrigerators
Hja6100 leisure freezer control panel not on, when I press the dispenser to let water out, no water is coming out. What's the problem
2 Suggested Answers
SOURCE: Maytag Ice20 refrigerator
Thanks, Solution #3, for the phone number ((800) 688-9900)! We, too, have the Ice2O refrigerator, and the HV Board started the disco light show last night. Followed instructions above to disable it, which temporarily solved the problem. Was on the phone with Maytag (Whirlpool?) this AM, and their initial response was that they wouldn't cover anything since we are out of warranty. I had to be extremely firm with my expectation that all parts and labor would be covered. Sent the rep back to her supervisor several times until they agreed to cover both. If you find yourself in a similar situation, don't give up until everything is covered. This is a design issue that should NOT be impacted by an expired warranty!
Posted on Apr 15, 2010
Panel beeping and nonresponsive
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 30, 2016 | GE Profile Stainless Bottom-Freezer...
There is a constant buzzing noise coming from the lower freezer ice maker. It is producing very few ice cubes. The control bar is down and in proper position to make ice.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 21, 2015 | Whirlpool Gold Series GB2SHTXTS (219 cu...
The refrigerator makes 6 beeps after dispensing water. Everything seems to be working normally so I do not understand why it beeps after the paddle returns to its normal position.
Apr 05, 2015 | Refrigerators
My Leisure HJA6100 with ice maker and chilled water dispenser now tripe the main circuit breaker for that part of the house when switched on. The plug 13amp fuse does not blow but the consumer unit tripps/...
A breaker trips when the current draw exceeds specifications. This is usually a short or where a component has failed and drawing excess current. It is also a good thing as it prevents a fire! The likely culprit on a fridge is the compressor and that is not usually a DIY job. You can poke around looking for evidence of arcing or overheating but likely a service call.
Jan 08, 2015 | Refrigerators
My Leisure HJA6100 icemaking unit is making a terrible noise, which stops when I open the freezer door. It's just a year old, what could be causing this noise?
Your evaporator fan motor would be the cause of your noise. Yes, it can be repaired, just need to replace the fan motor. The noise stops when you open the door because the fan motor turns off when the door is open.
Mar 13, 2013 | Refrigerators
I have a Leisure HJA6100. The ice dispenser has stopped working.
Yes indeed... but much depends on how hard your water is and the condition of your pipes feeding to your ice dispenser... pipe rust and particles = clogged filters.
I tried to find a schematic diagram to see if there is a water pressure sensor switch somewhere, but no luck... sorry... it was a thought.
But I discovered your filters are quite expensive and none are to be found on eBay and that's highly unusual! One filter will cost you about $60 ~ no thank you.
I would do my best to remove that filter MOUNT and install a "inline" filter that will do the same job and for a LOT less. Add few PVC adapters, maybe a short length of copper line and 2 rubber sleeves and you are back in business... at least filter-wise.
Extend the lines and you can place that filter almost anywhere. The second link shows your FILTER MOUNT... and looking at this photo it looks like it can be a fairly easy job.
You do not want to keep hunting and paying $60 and more for "exotic" water filters so here is a decent GE GXRTQR Inline Filter, 3-Pack for $22.88 including shipping.
Anthony
FILTER HEAD (to gather a few adapters)
Leisure HJA6100 Water Filter Head
eBay 3 Pack FILTERS
GXRTQR Inline Filter 3 Pack eBay
ASSORTED PARTS
Leisure HJA6100 Fridge Freezer Parts Replacement for GE
Dec 02, 2017 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
