Daewoo washing machine DWC-ED1221 starts to spin and stops
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
SOURCE: Washing machine
Normally these spin problems are just a blocked filter, which is located at the bottom of the washer behind a white panel which you can undo with a coin, drain water first, undo plug from hose into a bowl etc then take out filter and clean, hope this helps.
Posted on Mar 09, 2009
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Model DWC-LD1421 WHAT DOES FAULT CODE LE MEAN ON THIS MODEL
this is the code issue for the Daewoo washers things to check The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
  • Close the door!
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
My Daewoo DWC-UD1212 washing machine does not spin; and shows IE whenever the light indicator is on Spin. What should I do?
not sure bout the IE error But I would check the clutch, the motor coupler, the door switch, and the belt if applicable?
Feb 28, 2015 | Daewoo Washing Machines
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
Installation instructions DWC/CV701PC
Is this : http://www.daewoo.cl/sta/manuales-tecnicos/Manual%20Tecnico%20DWC-300M.pdf what you are looking for?
Oct 07, 2014 | Washing Machines
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
The washer will not drain
you might want to post this in the washing machine section
Aug 17, 2012 | Cars & Trucks
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Machine starts spinning but stops in between
am having the same problem just now when am trying to do my washing this morning and now my husband is trying to open the front cover at the lower front of the machine. You have to unscrew it then you might have to clean the pump. It must be clogged and needs cleaning. Good luck!
Feb 20, 2009 | Daewoo DW500M Top Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
