Question about Stihl Garden
Replace recoil spring
Broken spring
  • Stihl Master
  • 1,807 Answers
Which model?
Posted on Feb 27, 2016
4 Suggested Answers
  • 8 Answers
SOURCE: Broken recoil starter spring
try your local mower shop tell what type it is the modle number and make the should be able to cross refrenesss it and get the right one
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: how do you disassemble the
Try this web site smalleng.com and watch one of there videos. Also you can try U-Tube they also have great tutorials. Good Luck....
Posted on Aug 31, 2011
  • 316 Answers
SOURCE: Victa Sabre Edger recoil spring
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,MrFixIt,thank you.
Posted on Feb 20, 2012
Cord stuck on RYi 2200 digital inverter generator
It sounds like your recoil has broken. You need to get to the recoil and see if you can get the spring within it to reconnect to the recoil housing or replace the recoil if it is broken.
We hold the parts if you need them. :)
https://www.generatorguru.com/ryobi
Mar 10, 2017 | Electrical Supplies
Starter cable is stuck
unscrew top and check recoil drum if doesnt turn back possible broken spring following links should help
An easy way to fix pull start recoil spring How to Replace the Recoil Spring in an MTD Motor Lawn Mower About com Search Find it now
Jul 27, 2016 | Garden
HOW TO REPLACE RECOIL SPRING IN FG110
the rope probably has broken at some point and they did not relode spring enough take the take the spring housing off remove the rope relode spring stick a screwdriver in it to keep it there put rope back on pull screwdriver out put it back on
Apr 26, 2015 | Honda FG110
Broken spring in recoil starter on lawn mower
While I have not done this on newer model lawn mowers, I have replaced recoil springs in the past. Here's what I did: First you need to pull the spark plug wire off so the engine will not start. Then block the flywheel with a piece of wood to keep it from turning. Then, using another piece of wood such as a short (6-8 inch) hardwood dowel placed against the ears of the recoil drive, and drive it in a reverse direction (clockwise) with a hammer to knock it loose. It may take several sharp blows to break it loose. The recoil drive is reverse threaded to keep it from coming loose when the engine is running. Once the drive is loose, remove it to get access to the recoil spring which must be replaced if it is broken. With a new spring in place, rethread the recoil drive counter clockwise until it is finger tight. Then, tighten it down with one sharp blow against the wooden dowel.
Jul 10, 2013 | Garden
Have champion 3500 watt generator recoil pull cord wont recoil HELP
need to take the recoil off the engine and check for a broken recoil spring, depending on the engine if it is a honda, they sell a replacement recoil unit, anything else and you will have to get creative....try tapping on the recoil with your palm and see if it trys to rewind, if no resistance or movement when bumping is a good indicator of a broken recoil spring....
Dec 14, 2011 | Electrical Supplies
Starter rope broken on victa mower. how do i rewind. Itwill not recoil once pulled out
It sounds like the recoil spring is broken. Take off the recoil unit and remove the pull plate replace the spring if it requires itl davidson lawn mower tech
Feb 08, 2011 | Garden
Pull string won;t recoil
The recoil spring has broken. These are available at any lawn mower parts supply store. The process of changing the spring is tedious but can be done by anyone with average mechanical ability. If you removed the recoil assy (and air shroud if it is riveted on) and took the assembly to a Lawn Mower Repair shop usually they will change out the spring while you wait. If you can't get the recoil assy off take the mower with you to the repair shop. Again most shops will fix it while you if wait but if they are very busy usually they are serviced within 24 hours.
If you do attempt this yourself check in the tips section of FixYa on how to change the recoil stater rope after replacement of the spring.
I highly recommend you replace the pull rope at the time of the recoil spring replacement.
One final note... there is a possibility that the pull rope spool has been damaged where the spring attaches.
Thanks for using FixYa,
Kelly
Apr 28, 2010 | Mtd 22" Yard Machine Push Mower
Recently, the rope recoil mechanism on my lawnboy mower would not recoil completely or not at all. I removed the complete recoil assembly and the rope in order to rewind the coil, which appeared to be...
Im sorry but it sounds like the spring has broken. So I am not that familiar with Lawnboy but some rewinder are not serviceable and the whole housing has to be replaced .
Oct 22, 2009 | Garden
Recoil spring broken
you need to supply the brand and model of the blower so i can look it up
Feb 13, 2009 | Poulan 12a Elec Blower/Vacuum
THE STARTER REWIND SPRING IS BROKEN
you can not fix recoil spring all you can do is replace it.never said what the recoil is on so cann't help till you tell what it is on........
Dec 25, 2008 | Garden
Garden Logo
29 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
