Question about Refrigerators
Bosch kgu32165gb fridge fine freezer not working properly
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
  • 38 Answers
SOURCE: we have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Posted on Mar 14, 2009
  • 9 Answers
SOURCE: Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
  • 219 Answers
SOURCE: Fridge on Zanussi ZX56SI has stopped working but freezer fine
check in your frezzer on the back wall if its all frosted up u have a defrost problem u can unplug and let thaw fgor 4 or 5 hrs plug back in and wilkl work till u can have it serviced if no frost u might a bad fan or a damper control
Posted on Mar 19, 2009
SOURCE: Bosch Classixx fridge / freezer
Hi - experienced this myself and spent ages trying to get to the bottom of it - only found one post but it worked and was absolutely clear on the cause nb: i'm not an "expert" !
My understanding of how the Bosch f/f works is that the freezer compartment generates the cold air for the fridge which is regulared at the fridge end . At the back of my fridge there are two "vents" which feed up this cold air up from the freezer into the fridge.
Problem happened to me because I left the freezer door slightly ajar which generated a massive amount of frost (sucking in the moist air from the house I guess then freezing it) and subsequent ice froze up the cooling ducts between the freezer and the fridge. Therefore, no matter how much I turned up the fridge thermo it never got cool. Only solution was to dump my frozen at a mates house and defrost the the FREEZER for a good 24 hrs +.
Worked tho' - fridge was completely back to normal.
PS: I understand this issue may also happen if you put too much unfrozen food into the freezer at one go and in working overtime to get it frozen causing a massive frost up again.
Posted on Apr 17, 2009
My Bosch kgn33v00gb fridge/freezer is up the spout. The fridge is not cold at all, but freezer is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 08, 2011 | Bosch Refrigerators
I have a bosch fridge freezer model kgu3220 gb. It is ten years old. For the last few days, the fridge isn't cooling but the freezer works fine. The temperature on control panel is stuck on 11 degrees. I...
Once the fridge is shut OFF for few hours to defrost and then switched ON , if the fridge works with cooling , then the fault is with the AUTO DEFROST TIMER or the circuit -maybe the heater, break in the lines to the timer, heater, the fan.
The build up frost will block the flow of cool air to the fridge from the freezer evaporator.
So remove and check.
Jan 13, 2011 | Bosch Refrigerators
Hi there, we recently purchased a Bosch Platinum side by side fridge and freezer model number KAN56V40AU. The problem we are experiencing is that the fridge section is not cold enough and the temperature...
you will be able to get a technician out under warranty to properly diagnose the fault
you do not have to return it as they will come out for the job
call the service agent listed on the warranty booklet
don't touch it your self as that will void the warranty
Jul 14, 2017 | Bosch Refrigerators
Bosch fridge frezer
gas is sealed for life....sounds like it is auto defrost mode.leave switched on. after a full manual defrost. for at least 24 hours to settle down keep door shut... then check. should reset itself.make sure all vents,drains are clean.
Feb 14, 2010 | Freezers
Suspected broken fan prevents top fridge section cooling down
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Jul 29, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Mar 14, 2009 | Bosch Refrigerators
Bosch classixx fridge freezer. Freezer working fine, fridge not reaching a decent cool temperature. slighlty cool only.
Defrost fridge, remove product from freezer and store temporarily in another freezer, defrost at least o/night, then try again.
Nov 04, 2008 | Bosch Refrigerators
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
We have the Bosch kgn34x60 fridge freezer and the fridge wont stay cold. The dial is turned to 5. Any ideas on what might be the problem????? had it less than ayear and the freezer is fine
I have this model and am having the same problem. Bosch don't want to know as it is out of warranty.
This means that a perfectly good freezer has to be thrown away because the fridge won't work properly.
Don't buy Bosch.
Jun 01, 2008 | Refrigerators
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
