Question about Panasonic Office Equipment & Supplies
Please set up dial mode - Panasonic Office Equipment & Supplies
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
I have a Nikon D3100 and surprisingly the dial mode does not work properly. I mean when I turn it, at some modes, it shows the selected mode correctly on the display, but not for all
Hello mehran_vafae, is supposed to have put a DX lens.
The mode dial, select in what way is going to take a picture.
You can make combinations according to the mode set in the mode dial, with the Fn key / command dial, command dial / aperture A mode, command dial / shutter speed S mode, Full Auto / + / - compensation sw, etc. ..
Please carefully read the user manual supplied with your camera and if it fails take them to Nikon service.
Regards
Mar 21, 2011 | Nikon Cameras
I am in the "s" mode for shutter speed priority and i cant change the shutter speed i use the scroll to get the arrow above the shutter speed on the view finder and from then i cant figure out how to...
Are you pressing the jog dial to save the setting? Here's what your book says:
  1. Turn the Mode dial to P, A, S, M, or C.
    The mode options are displayed.
  2. Use the jog dial:
    • Press the jog dial to open a setting.
    • Press the jog dial to save the setting.
    NOTE: Available options are white. Unavailable options are grey. Red options are out of range and may cause unacceptable image/print quality. Adjust the value higher or lower until it turns yellow.
Jun 11, 2010 | Kodak EasyShare DX7630 Digital Camera
How to use flash on a vivitar vivicam 8690
Look on the Mode Dial find a small icon looks like a camera, rotate the Mode Dial to select.Toggle the flash settings. Look on the Mode Dial and find a small icon that looks like a camera, then rotate the Mode Dial to select this setting. This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya
Mar 17, 2010 | Cameras
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
I want to put color bar in pd 170
dear when u will open menu .. at last where we check ..HR. METER ,if u remmber ...
der is the option for the colour bar
Jan 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Olympus c-8080 stuck on movie mode. Mode dialing has no effect.
I'VE DONE A LOT OF READING ON THE OLYMPUS SITE AND IT SEEMS LIKE YOUR CAMERA MIGHT JUST HAVE BEEN SET ACCIDENTLY IN MOVIE MODE AS THE DEFAULT SETTING AND THAT IS WHY MOVING THE DIAL HAS NO EFFECT. THE PROBLEM BEING I HAVE YET TO DISCOVER THE TRICK TO REVERSE THIS DEFAULT SETTING FROM MOVIE AND BACK TO THE FUNCTIONS OF THE MODE DIAL. YOU ARE POSSIBLY IN A BETTER PLACE TO DO THIS PART OF THE FIX. I AM HOPING BY HEARING THAT IT IS IN A DEFAULT SETTING YOU MIGHT KNOW WHO WOULD HAVE DONE THIS AND HAVE THEM RESET THE CONTROL TO NORMAL.
IF THIS DOES NOT PRODUCE ANY RESULTS, PLEASE REPLY TO: ARCLIGHT1217 AND I WILL DIG DEEPER INTO THAT SITE TO FIND THE SOLUTION TO RESET THE DEFAULT! I WON'T LEAVE YOU HUNG IN TOON TOWN! WE'LL GET IT.
ARCLIGHT1217
Oct 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
18 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
