Question about HP LaserJet 2420 Printer
2420rfu no installation and no print
    New Friend:
  • 12 Answers
What is exact problem ???
Posted on Jul 15, 2013
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
ERROR MESSAGE U051
Print head not installed,
or not properly
installed.
[1401] U051 Print head is not installed. Install
the print head.
Install the print head properly.
It may be that print head is defective or main PCB assy
Jan 12, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
Nov 25, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Cannot print with only one cartridge
The inkjet printers are designed to print wit BOTH cartridges installed. You cannot fool it to print with only one.
Apr 18, 2009 | Computers & Internet
Can't find ink storage
look at this
Details Issue: How do I replace or insert an ink tank?
Solution: Install the Print Head and Ink Tanks - MP620 / MP620B
  1. Open the Paper Output Tray (A), then lift the Scanning Unit (Cover) (B) until it locks into place.
    The Scanning Unit (Cover) (B) is fixed automatically.
    The Print Head Holder (C) comes out. (This is where you install the Print Head.)
    Note : Close the Document Cover (D) and lift it with the Scanning Unit (Cover).
  2. Raise the Print Head Lock Lever (E).
    i_expl.gifCaution : Firmly raise the Print Head Lock Lever until it stops. (The Print Head Lock Lever may feel heavy.)
    i_note_e.gif Note : If the Print Head Holder does not move, make sure that the machine is turned on.
  3. Remove the Print Head from the silver package.
    i_expl.gifCaution : There may be some transparent or light blue ink on the inside of the bag the Print Head comes in, or the inside of the protective cap - this has no effect on print quality. Be careful not to get ink on yourself when handling these items. Be careful not to stain your hands.
  4. Remove and discard the orange protective cap.
  5. Tilt the Print Head and set it in place. Lower the Print Head Lock Lever (E) completely.
    i_expl.gifCaution : Do not knock the Print Head against the sides of the Holder.
    Be sure to install it in a well-lit environment.
    Pinch the Print Head Lock Lever firmly and lower it gently.
    Once you have installed the Print Head, do not remove it unnecessarily.
Install the Ink Tanks
  1. Pull the orange tape (1) in the direction of the arrow to peel off the protective film and remove the film (2) completely.
  2. While pressing down with your left thumb, twist off the orange protective cap (A) located on the bottom of the ink tank.
    i_expl.gifCaution : Do not hold the sides of the ink tank; ink may splash.
  3. Install the Ink Tank
    Press the PUSH mark on the ink tank until it clicks into place.
    Make sure the Ink lamp lights red.
    i_expl.gifCaution :Be sure to install it in a well-lit environment
    i_important.gif Important : Match the labels when installing.
  4. Install all the other ink tanks in the same way.
    Install all the ink tanks.
    i_expl.gifCaution :Once you have installed the ink tanks, do not remove them unnecessarily.
    i_important_e.gif Important : Make sure all the Ink lamp lights red.
  5. Close the Scanning Unit (Cover) (B).
Mark
Apr 16, 2009 | Canon PIXMA MP620 All-In-One InkJet...
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon i9950
Seems impossible to reset the counter, is there a way to manually reset?
Oct 10, 2007 | Canon BubbleJet i9950 InkJet Photo Printer
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP LaserJet 2420 Printer Logo
11 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
