Question about Ovens
Shacklock oven shacklock orion 21.grill working oven not.turn oven on and grill comes on.
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
My cooker is new ihave it wired up but when i turn on the grill the oven comes on and when i turn on the oven the grill comes on is the wiring wrong please help
If you had wired the oven up incorrectly, it would not be working at all, sounds like a prob with oven.
Please rate my solution.
Thanks.
Nov 01, 2009 | Ovens
How do I reset the clock on a shacklock multifunction oven? Has 5 buttons, timer, a picture with what looks like steam above a square, auto/man and a knob that can turn either left or right.
press timer (picture with bell) adn cooktime ( picture with what looks like steam above a square) buttons simultaneously while turning adjacent knob clockwise until readout registers current time. Release both buttons and clock is reset.
Oct 09, 2009 | Ovens
How do you replace an oven door lining
no need of spl.tools it can change by openig screws left bottom of the door
Aug 05, 2009 | Fisher Ovens
Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
Oct 04, 2008 | Stoves 720EF Electric Double Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
