Yamada DVD-5520 DVD Player
Problem for Yamada DVD-5520 DVD Player
I Can Not Find a YAMADA DVD-7600XTV Region Unlocker
By andrewnmann1 on Mar 29, 2009
I can not find Unlock Region Codes For A YAMADA DVD-7600XTV.
I Can not find RP1 Firmware For A YAMADA DVD-7600XTV.
Can You Email me with RPC1 Firmware updater (the DVD Player can update via usb or SD memory Card. (with Link to RPC1 Firmware)?
Can You Email me Region Unlock Codes?
Comments:
Mar 31, 2009
- I tred on Yamada DVD-7600XTV (it is not Related to DVD-5500 DVD Player).
Mar 31, 2009
- When I press Setup on The Remote Control DVD Setup, DVD Menu, DVB Menu (Un Highligted), System Setting, Game, Exit Appears.
Solution #1
posted on Mar 30, 2009
Somewhat Helpful)
Beignorant
Rank: Wiz
Rating: 83%, 39 votes
I don't know if this will work but I can atleast try to help
1) Open the disc tray.
2) While the tray is open, enter the following code with the remote's numeric pad: 2812
3) To change the region code, press the "Enter" button repeatedly. "Region 9" means all regions will be enabled.
4) Close the tray to save the desired setting.
Other Zoran Vaddis 776 based players have other options on this screen (such as Macrovision Enable/Disable) but this player only offers the region code setting (note the unused available space for other menu options).
If you press "Display" on the remote, the firmware version will be displayed.
or
1. Press "Eject"
2. Press "Setup"
3. Press 3x on the right "Präferenzen-Setup"
4. Press 7x Down "Land"
5. Press 1, 3, 7, 9
6. And 0 for code free
7. Press "Play"
Comments:
Mar 31, 2009
- hmmm...tricky....I'll see what other data I can gather for you.
Mar 31, 2009
- It should either be DVD SETUP or DVD MENU. Would you mind trying out the codes on those two? If all else fails and I am no help, try phoning your manufacturer. The MUST give you the codes to unlock your Dvd player since it is actually illegal for DVD layers to be locked on certain regions.
Was this helpful?
Yes
No
Popular Solutions for Yamada DVD-5520 DVD Player
Questions and Unsolved Problems for Yamada DVD-5520 DVD Player
Do you recommend Yamada DVD-5520 DVD Player?
Answer
Answer
Sony DVP-S300 I have had this DVD player for close to ten years. It has always worked wonderfully.... (More)
Answer
Good Morning When I turn my DVD player on the picture on the TV is jumping I have tried a disc to... (More)
Answer
i need code for programming a sony remote to do a yamada dvd player
Answer
I have connected the Yamada DVDSlim 5520 to my TV using a Scart.I also tried connecting it through... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Yamada DVD-5520 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
