Question about Refrigerators
Hotpoint ctx21da refrigerator collecting water on bottom under bins
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
aborcass
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
docjohn174
  • 943 Answers
SOURCE: water in the bottom of the refrig
HI thanks for your question. the drain tube is clogged. to repair turn fridge off, for at least 24 hrs. as the frain tube is between the inside and outside wall. so its just not dirt in the drain tube, its frozen . to clear after 24 hrs . purchase a small plastic tube , go to the drain tray at the back shove the small hose up the drain hose and blow air up the tube . it will unclog. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 12, 2008
  • 531 Answers
SOURCE: water collecting inside the bottom of the refrigerator
you have clogged drain
Posted on Apr 07, 2009
SOURCE: Water collecting in bottom of refrig Hotpoint
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
Hotpoint model CTXZ1D1BBRWW has water collecting in the bottom of the fridge under the produce bins. I can not see any water running down?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Apr 14, 2011 | Hotpoint Refrigerators
Water is dripping down the back wall of my hotpoint refrigerator model # CTX21DA. The water collect at the bottom and drips onto the floor. How old is the refrigerator and what would the cause be for...
The problem is relatively simple to repair. The drain tube in the freezer is blocked so the water will drain down the back of your fridge. Often the drain gets blocked by ice build up. The defrost circuit in your fridge has failed and ice is building up on the evap coil in the freezer. When the ice builds up, it blocks the drain tube. The typical failures of the defrost is the timer failing to advance or the heater is burned out. Being that said it was probally manufactured at least10 years ago, and certainly a new refridgerator would be more energy efficient and cheaper to operate than using a 10 year old model. Whether you should repair or replace it depends on whether you have the money to replace it. Hope this helps you.
Dec 06, 2010 | Hotpoint Refrigerators
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
What year was the hotpoint refrigerator CTX21DA made?
Good day,
Sorry, but this is what they came back with...
Quote: This product could have been manufactured April of 1974 or 1986 or 1998 or 2010.
Jan 24, 2010 | Refrigerators
Water collects in bottom of refrigerator under fruit/vegetable bins
When a fridge goes in to defrost it melts the ice on the coils in the interior of the freezer. Often times there is a drain that runs to a sliding tray under the fridge. If this is clogged you will get water building up under the bins.
Jul 10, 2009 | Refrigerators
May 14, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaks under veg bins.. Cannot tell where it is coming from. Accumulates slowly
This refrigerator look like mine (Picture).
Mine did the same thing. If it is the same then this is what I did.
Look under the there is a collection tray.
This tray collect the water.
At the bottom of the refrigerator (Inside where the water collect) is a cap.
The cap has cap would have holes or a slot that allow the little water to fall to the collection tray.
Mine has slots and was block up.
clean it out and that should do it.
The water should be able to fall to the tray at the bottom.
I do hope this help you.
Mar 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint refrig model CTX21EPJR
there is a drain gulley on the back wall with a drain in the middle. this drain is blocked. push something flexible down it and follow up with a small jug of water to make sure it flows away freely
Jul 06, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
