Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Electrolux refrigerator french door-the perfect temp drawer is leaking
5 Suggested Answers
SOURCE: I have an electrolux wave touch french door
pull the ice tray out, on the bottom of the left side there's a metal rod that needs to be repositioned into the tooth gear.
Posted on Oct 22, 2010
SOURCE: Electrolux EW26SS65GS0 Refrigerator. Temps going
Same problem for past month, tried replacing motherboard and today still showing Red High and adjusting....$500 so far and three service calls...what to do...food thrown out and good thing my garage is cool to store some stuff.....
Posted on Dec 22, 2010
  • 1531 Answers
SOURCE: Electrolux side by side door refrigerator. White
This can be pulled out of the door and replaced with new tubing.You may need to remove the front dispenser panel in order to get the tubing out of the dispenser.
Once you do that then you can pull the remove the tubing and replace it with new line.
Posted on Jan 01, 2011
  • 4 Answers
SOURCE: We have purchased an Electrolux
it could be refrigerant leak or fan don;t run
Posted on Aug 06, 2011
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Error codes 5Y EF
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 28, 2016 | Electrolux IQ-Touch 27.8 cu. ft. French...
How do I completely clean the Electrolux Perfect Temp Drawer? Gravy has gone in-between the plastic parts.
Hello Gayle, thank you for your post!
I understand that gravy has fallen into the perfect temp drawer on your Electrolux refrigerator. In order to assist you further I would need to have the model number of your refrigerator. You can locate the serial tag (which lists your model number) on the inside wall of the fresh food side. With that model number I can research to see what additional information I can provide you with. I look forward to assisting you further. -Matt
Jan 02, 2016 | Electrolux Refrigerators
Take apart Electrolux crisper drawer
Model numbers are found on the inside wall of the fresh food compartment around the door or on the back of your refrigerator. What is your model number?
Appliance 911
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Have a Electrolux refrig. french doors and bottom mount. model ei23bc56iso Its shut off. The display in front at the dispencer says OFF at frezzer side and OFF at refrig side. No other displays or error ...
  1. Bottom Mount Refrigerator Ice Maker. When the bottom mount refrigerator is placed in Sabbath mode the ice maker will be automatically disabled. Please be aware however, that although you have entered the Sabbath mode, the icemaker will complete the cycle it had already initiated. The ice cube compartment will remain cold, and new ice cubes can then be made manually in the freezer section (using a standard ice cube tray) as needed for that Sabbath/Holiday.
  2. Sabbath Mode and the Perfect Temp Drawer (if equipped). The Perfect Temperature Drawer should be turned off for the Sabbath/Holidays. Before putting the refrigerator into the Sabbath mode, turn the Perfect Temp Drawer off by pressing the drawer on / off button. The display will show "OFF" and the drawer will turn off. Then enter the Sabbath mode function on the main refrigerator display. The drawer display will now not illuminate and the drawer will remain off until Sabbath mode is exited and the drawer is turned back on. The drawer can still be used as a non temperature controlled drawer in this mode.
  3. Press the display button few seconds and recheck.
---------- Check out thanks.
Aug 27, 2010 | Refrigerators
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
15 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
